Question about Refrigerators
We have moved into a new home and our refridgerator is just a tad too high to fit under the cabinet...
  • 4,793 Answers
You dont say what make/model you have but anyway,have you looked under the f/f to see if the feet are removable but still allow you to open the doors??.or if you remove the feet,can you use spacers to make it fit/open doors.
Posted on Aug 05, 2010
What else can i try?
I am not able to see all the answers you were given so hopefully i wont repeat.
if your recess is cabinets, you can always remove the ones over where the refridgeration unit would be placed and if at all possible rehang them just a little higher. if the difference is very visible you can use crown modeling or modeling strips to make the cabinets appear in line. you could also just remove the cabines and then make a false front using the front of the cabinets and moving them higher or shaving off portion of the cabinet.
another idea would be to make sure the adjustable feet on the unit itself are in the lowest position possible and still level the unit. if you have to remove the feet and use shims to level you could do that as well. if the recess is made of dry wall, you can simply cut the dry wall to the specifications you need and tape and sand the drywall where you removed it and paint over that portion to make the look of the wall appear to be new.
if the space you need is large, and is dry wall. remove it totally where it does not fit and and rebuild the wall.
hope that helped.
Aug 28, 2014 | Refrigerators
How do you lower the height on a LG washer and pedestal? It's too high by 1" to fit under my wall cabinets.
The pedistal has 4 leveling legs on the bottom of it you can adjust to a certain point. You may have to take the lefts off completely and if it still doesn't fit, you unfortunately didn't measure properly.
Mar 16, 2013 | LG WDP4W 14 inch Pedestal White
I have a 1992 lexus the gas pedal stopped working when i was on high way the car was still on but would not move .had it towed home now when i try to start it or i wanted to just move it back in drive
First the throttle, the cable may have come off the throttle body. Power steering, my 95 es300 had the same problem. It was the high pressure line. The way to fix that is to get a 6' high pressure line, cut your old fittings off both "ends" , have a shop put the fittings on the new hose and re-route, re-feed the now solid one piece line as needed. Hope that helps
Jul 25, 2012 | 1992 Lexus Es 300
Connecting a indesit iwdc6125
you can fit it you have to trim the continuous plinth either side of cabinet . also check your new washer will fit under the worktop freestanding appliances are 85cm high integrated are 82cm.
Jul 16, 2010 | Washing Machines
Dont know were the port is to charge my air on 1999 for expiditio
there are two lines under the hood from the compressor, the one that is located in the larger of the two lines is the charging port, you say your charging nipple doesn't fit on either? are u using R134 refridgerant charging adapters? they are very large in comparison to the older R12 refridgerent system which was phased out in 1993.
Apr 08, 2009 | 1999 Ford Expedition
Dishwasher for 32 inch cabinets
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Jan 05, 2009 | Dishwashers
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
