Question about InFocus IN24 Multimedia Projector
Projector keeps shutting down every 20 minutes. Could it be the fan or the bulb? or something else?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
Look at the lamp and check to see if there is foil tape over the seams on top of the lamp. The top is the side under the top cover of the lamp when installed. If the foil tape is absent, then the heat escaping from the seam is triggering the thermal sensor in the lamp housing causing the premature shutdown. If your lamp does have tape on it then your lamp is probably going bad.
Posted on Aug 05, 2010
Projector shut down
happened to me something similar to what reported, only the small fan sometimes went off within minutes and sometimes seemed to work for hours
The room temperature was around 20 degrees, so the problem was software or hardware, but on the internet I did not find other people with this problem or fix
I did not update the firmware for the loss of the warranty, which I am thinking of claim
Feb 12, 2013 | Optoma ML300 Multimedia Projector
Canon LV-S1 projector keeps shutting down after a minute or less
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Jul 15, 2012 | Canon LV-LP12 Projector Lamp for LV-S1,...
My Sony VPLHS-20 has original bulb, now just shut off 50 mins into the SuperBowl. No fault light, in fact, no lights showing on the display at all. Bulb has around 1800 hours. I waited 10 minute, red...
Pretty sure it the bulb as most are rated at 2000 hours; but also check for full air flow - clean filters etc. Bulbs can run hotter as they age, so air flow is more important, because there is an inside heat sensor that will shut the machine down.
Feb 09, 2011 | Sony VPL-HS20 Multimedia Projector
Powers off
clean out the projector with canned air. dust keeps in the heat the projector is trying to expell. once it's blown out, check the fans to make sure they are spinning.
Nov 11, 2009 | Office Equipment & Supplies
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Aug 29, 2009 | Mitsubishi XD480U Multimedia Projector
My viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
Panasonic projector keeps shutting off
http://www.youtube.com/watch?v=6jGwB05_gdk
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Runco Cl 610 keeps shutting down
on the cl-610 it would shut down after about 5 minutes of running..as well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
Nov 27, 2008 | Audio Players & Recorders
InFocus IN24 Multimedia Projector Logo
202 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
