Question about Kenmore Microwave Ovens
The oven will not work. I checked the fuses and they are good.
    Sergeant:
    Champion:
  • 277 Answers
Is this a dead mirowave or semi dead. the display works, light works in the oven when door opens.
If this is the case... you may have a power supply board failure or the magnatron is defective
Check the power supply first, because it would be cheaper to repair then the magnatron
Posted on Aug 05, 2010
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
Model pod712mw microwave doesnot work oven simply stopped working
If there is a fuse, it will be located inside the oven behind the control panel. Gain access to the panel and inspect for signs of fuse. If not, and the oven has no power whatsoever, for any function, and the power supply is good, then there will be a fault in the appliance somewhere. Most likely the brain.
Generally, the fuse is located in one of the panels on the front, behind the control panel/knobs. Keep in mind that a lot of stoves don't have the fuse no, its silly really. I reemmber in other customer problems that the problem was a temperature control regulator that had burned out,
Will need to check and re-check all internal components in your device.
Hope helps.
Jul 14, 2011 | Microwave Ovens
Was using the microwave and then ... nothing...everything went dead...checked the circuit breaker...but it was o.k......what's wrong? It has been working fine for about 6 years with no problems.
IF YOU REMOVE THE OUTER COVER FROM THE OVEN ABOUT 8 SCREWS AND LOOK TO THE REAR OF THE OVEN THERE SHOULD BE A FUSE THIS COULD BE THE PROBLEM IF THE FUSE IS GOOD GET ANOTHER OVEN TO REPAIR WILL COST MORE THEN A NEW OVEN
Feb 06, 2011 | GE JVM1650 1000 Watts Microwave Oven
Heating system failure
Please you check temperature switch. It is OK or not.
2. Check fuse ( if any ) Ok or not.
3. Check Selector switch. it is good or not.
Ngajio
Jun 03, 2009 | Samsung MT1066SS Convection/Microwave Oven
Vent and lights do not work on over the range microwave
Check for another fuse. Check all electrical connections for burns. Did you check fuse with a meter or just look at it? Don't trust what it looks like.
Mar 27, 2009 | Amana MVH210W Microwave Oven
Microwave blowing fuses when setting programme
suspect high tension diode or bleed diode faulty. easy to replace but!!!!!!!!!!!!!!!!!!
BE CAREFUL. THERE ARE VERY HIGH VOLTAGES PRESENT IN A MICROWAVE. YOU MUST SHORT CIRCUIT THE CAPACITOR WITH A GOOD QUALITY SCREWDRIVER IE GOOD INSULATION. VOLTAGE CAN BE UP TO 1500 VOLTS AND IT CAN KILL.
IF YOU ARE NOT SURE WHAT TO DO, GET SOMEBODY IN
Jul 05, 2008 | Neff H7871N2GB Convection / Microwave Oven
Heating problme on microwave
Unplug power open cover detach on side of terminal wire check fuse test w/ multi tester both end of fuse if reading good but not reading /replace fuse same amphere.Check also the diode pop or not / if not ok. treturn all screws and test microwave.
Jan 05, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Whirlpool GH7145XF
Check your main breaker fuse in your panel/subpanel.
Otherwise if the inline fuse is good and the main power is good, then look at the power supply for the microwave.
Mike
Nov 09, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
55 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
