Question about Nokia E63 Cell Phone
Headset enhancement is permanently activated even though none is attached and default pofile is set to handset. The results are poor volume quality for music or even alert tones and ringtones. How do i deactivate the headset profile?
SOURCE: n keypad sound, enhancement logo showing
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
Posted on May 28, 2008
battlesmith
  • 382 Answers
SOURCE: Headphone symbol
hi,
please contact nokia service centre for further assistance because the headphone symbol reveals that a headphone is connected which should not appear as you say..so please take your mobile to nokia care for service..thank you!!..
Posted on Jul 02, 2008
sean2100ad
  • 7 Answers
SOURCE: 110i/1112 Nokia cant activate headset option
generally wen you insert the headset pin it goes automatically to headset profile, if this is not working then go bak to the vendor & get the phones software changed
Posted on Oct 15, 2008
statione_k3n
  • 75 Answers
SOURCE: nokia 5200 music player problem
maybe the mp3 files youve inserted to your phone is converted...the bitrate of your mp3 should be atleast 128 so that you have a clear and enjoyful sounds
Posted on Feb 11, 2009
SOURCE: I cannot change the message
It took me many hours to work it out!
- Menu.
- Settings.
- Phone settings.
- Phone profiles.
- Select (highlight) the one you want &.
- Select OPTIONS with the left soft key.
- Click Edit (1).
- Use the directional key (right) to highlight the New Messages.
- Scroll down to Message Alert.
- Left soft key OPTIONS & select edit (as above).
- Then click the directional key until you hit either Downloaded Music or sounds (depending on where you stored your sound file).
- Select your file.
- Left soft key & select SAVE.
- Then that's it, done!
Please email me with if it works for u or not. mattconway1992@hotmail.co.uk
Posted on Apr 18, 2009
Tip
For nokia..u can also change the repair and manufacturing...
To check the IMEI (International Mobile Equipment Identity) Type-
*#06#
To check the phones Software revision type-
*#0000#
To enter the service menu type-
*#92702689# (*#WAR0ANTY#)
  • Serial number (IMEI)
  • Production date (MM/YY)
  • Purchase date (MM/YY) You can only enter the date once.
  • Date of last repair (0000=No repair)
  • Transfer user data to another Nokia phone via Infra-Red
Revealing the Headphone and Car-Kit menus
Please note that if you do these next tricks, the new menus can't be erased without retoring the factory default settings. To do these tricks you need to short-circuit the pins on the bottom of the phone next to where you plug in you charger.
1. To activate the "Headset" menu, you need to short-circuit pins "3" and "4". After a short time the word "Headset" will be shown in the display. Menu 3-6 is now enabled.
2. To activate the "Car" menu, you need to short-circuit pins "4" and "5". After a short time the word "Car" will be shown in the display. Menu 3-7 is now enabled.
EFR CALL QUALITY
To activate EFR (Enhanced Full Rate) Enter the code-
*3370#
This improves call quality but decreases batterylife by about 5%
To deactivate it, Enter the code-
#3370#
THE JAMES BOND TRICK
If you short-circuit theleft middle and right pins on the bottom of the phone with all connections touching each other, the Nokia software hangs! The profile "Headset" will be activated. Before you do this just activate the "Automatic Answer" in the headset profile and set the ringing volume to "Mute". Now you can use your phone for checking out what people are talking about in a room. Just place it under a table in a room and call it. The phone receives the call without ringing and you can listen to what people are saying.
on Apr 16, 2010 | Cell Phones
Motorola H19txt has very poor sound quality
sadly you have poor quality loudspeaker. the only thing u can do is plug in a powered speaker set into the headphone socket.
Nov 20, 2013 | Motorola Mobility H19txt Universal...
My headset was working fine but all of a sudden the volume will not stay at the level I turn it up to. It keeps rolling back down to barely any sound coming through. I try to use the button on headset but...
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to solve your problem. Your Logitech ClearChat Pro USB Headset's volume will not stay at the level you turn it up to, and as a result it keeps rolling back down to a lower sound quality. Your volume control button doesn't solve the problem neither. Well, when a problem occurs, you should first troubleshoot where it's coming from. We will use a method called "Process of elimination". Your headset's volume has two controls: one control is on the headset itself, and the other control is located in the sound settings of the device you have your headset plugged into. With this thought in mind, lets go up to the problem explanation above. You said that the volume control attached to the headset didn't make a difference, this means the you can eliminate the hypothesis that it's the volume control causing this. The problem is coming from the earphone portion of the headset. Either a mute setting has been activated, volume is turned down real low or your headset is not the default device to receive sound input. The first part of the investigation is done; now, to get further into the investigation, you will need to connect your headset to your computer. This is where troubleshooting and solving the problem meet. Step-by-Step, I am going to explain to you how to get audio presentations into your headset. This device works with two Windows Operating Systems (Vista and XP) and one Mac Operating System (OS X). If your computer's operating system is Windows, open your Control Panel. Under the Hardware & Sound link, click Manage Audio Devices (for Vista users), and the Sound & Audio Devices link (for XP users). If your coumputer's operating system is Mac OS X, open your System Preferences and click the Sound link. In Windows Vista, click the name of your device, then click Set Default. Click the Properties button and increase the volume slider or unmute the volume if needed. If applicable, click the Apply button, then click OK. If the Apply button is void, just click OK. Click the Recording tab and perform the same procedures as you did before, only difference is that this will make your headset microphone the default recording device. In Windows XP, click the Audio tab and set the headset as the Sound Playback and Recording device. Increase the volume or unmute it if needed. When finished, click the Voice tab and perform the same procedures as you did before. In Mac OS X, click the Input tab and select the headset as the input device. If you still can barely hear anything, increase the volume slider. When finished, click the Output tab and repeat the same steps as before; only thing, you will be making this the sound output device, meaning the sound of your voice will be outputed from the microphone. Increase the volume slider if needed. You should be able to receive sound in and out of your headphones now. If we succeded, through this experience we have: troubleshooted where the problem was coming from, found a way to solve it and fixed the problem! Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again the next time you need assistance with something. Thank you and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 27, 2011 | Logitech ClearChat Pro USB Headset
How to increase my nokia n70's internet connection & how to increase my headset's volume?
you may want to try this:
#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
for the headset volume, if your headset is the type that has volume controls or, check the side panel of your phone, try pressing arrow up to increase volume, arrow down to decrease, or go to the settings of your phone, look for headphones then volume
Apr 14, 2011 | Nokia N70 Cellular Phone
Does not ring
The Volume key allows you to adjust the volume level for the currently active audio device (handset, headset, or speaker). When no audio devices are active, pressing the Volume key adjusts the ringer volume.
Adjusting the Volume of the Ringer, Handset, Headset or Speaker
Note: By performing this function, default volume level will be replaced.
  1. Press the up or down arrow at either end of the Volume key to reach the desired volume level.
  2. When you are satisfied with the setting, press the Save softkey.
Note: When adjusting only the ringer volume, there is no need to press Save. The settings are automatically saved upon adjustment.
See the below link for user manual
http://noc.unet.maine.edu/IPT/7961_7941_User_Guide.pdf
Jun 20, 2009 | Cisco 7941G IP Phone
'in call' volume cisco 7940
The handsets will eventually go bad. If it is every single handset that you have, the problem is with the system. But if the problem is only with a few of your phones, you might consider replacing the handsets. We at IdacomUSA.com have replacement Cisco handsets for sale at only $25. Hope this helps you out :)
1-800-903-9190
Mar 04, 2009 | Cisco 7940 IP Phone
Every time I make a phone call My blackberry has a strange symbol
The icon is an indicator for the Enhance Call Audio feature selected on the device. The Enhance Call Audio feature is designed to allow a user to adjust the sound quality over the earpiece of the device (e.g. Boost Bass or Boost Treble)
To improve sound quality for all phone calls, complete the following steps:
  1. In the Phone application, display the menu and select Options.
  2. Click General Options.
  3. Change the Enhance Handset Call Audio or Enhance Headset Call Audio field.
  4. Display the menu and select Save.
To improve sound quality during a phone call, complete the following steps:
1. During a phone call, display the menu and select Enhance Call Audio.
2. Select Boost Bass, Boost Treble or Normal.
To review the different Selectable Phone Equalizers during a phone call, press the L key. The enhancement specific icons are displayed on the active call screen.
Feb 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Jan 12, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
N keypad sound, enhancement logo showing
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
7) Press Back
1) Hit Menu
2) Go to Settings
4) Select Headset
6) Select Silent
Regards
May 11, 2008 | Nokia 6230
Nokia E63 Cell Phone Logo
228 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
