Question about LG Televison & Video
I have 6 LG V271k-w1 DVD/VCR that seem to be outputting a fuzzy, black and white picture. It?s almost as if it's exporting in PAL, but I can't get it switched to NTSC. The deck's menu let me pick from Auto, PAL, or MESCAM, all with the same bad picture results. I tested the tv and cables with a working deck of a different model - no problem. Tested 3 other V271K-W1's, all with the same problem. Hooked it up to a computer, told the computer to expect a PAL format, and we got color, but the frame-rate was all wrong (picture rolled and skipped). Played in the deck's menus to try to adjust color/video signal - no change among PAL, MESCAM or Auto options.
fairlane
  • 50 Answers
SOURCE: Panasonic DVD-RV32 DVD Player-No image on RCA output
Hi Obviously the unit is playing the disk because your audio is fine, and getting some kind of black & white picture out of the composite, means that the video processor is probably ok. The most likely things to check then is the yellow video cable, (just swap the red or white in place of the yellow on both the DVD and your tv to test), or possibly the yellow RCA jack on the back of your DVD has gotten loose. If you have not done so, try wiggling it gently to see if your video comes back. If it does, and you are handy with a soldering iron, you can probably repair it yourself. Other than that, it would be a problem for a repair shop. (and a strange one!) Hope this helps, and good luck!
Posted on May 18, 2007
sambhu dayal
SOURCE: NO color output
DAV-DZ3k is a good sony product especially ...famous for book shelf speakers,the problem is basically due to the cables used to connect video terminals or the TVcircuits is not proper with the av receiver.. Thank you Regards Sambhu Dayal
Posted on Oct 07, 2007
CLUEPATEL
  • 138 Answers
SOURCE: Vertical addjustment for a DVD recorder
It should be inbuilt to switch on the vetical adjusment! or else you have to find another! 1
Posted on Dec 08, 2007
worldvet
  • 859 Answers
SOURCE: how to unlock it to play either NTSC/PAL
Here is the sequence to unlock your DV Player. Clearly this needs to be done exactly to access the secret menu. So, you may want to copy and paste this info into a word program and then print it.
- Begin -
1. Turn off NS55P, leave TV on.
2. Using the original remote supplied with the NS55P, press these buttons in order: DISPLAY, TOP MENU, CLEAR, POWER.
3. NS55P will turn on, displaying the secret menu on the tv screen.
4. Select 2: Drive Manual Operation, then 4: Tray Aging Mode.
5. The screen then shows two input lines: Input Count and Current Count. Use the code 00030 on the first line. Pressing zero first will take you back to the original menu, so instead of trying to type 0-0-0-3-0, try something like 1-0-0-0-3-0 so the 1 in the front disappears after the last zero is entered.
6. Press ENTER on the remote. Disk tray will then open and close automatically 30 times. Let it do this until it finishes.
7. Repeat steps 4-6, but instead of using 00030 in the Input Count, use 00000. Press ENTER, and the NS55P is now capable of reading Region 2 dvds.
- End -
Please ask any questions using the comment box below.
Regards,
Worldvet
Posted on Jul 07, 2008
SOURCE: PAL to NTSC conversion
This is not a converting unit, it will play the format of the tape inside. To convert the signal you need one of the following:
1) A converting VHS player; they are fairly expensive.
2) A separate video converter (hardware); they run for about $200-$500; just put this between your VCR and the TV.
3) Capture the PAL on your computer using a software like Movie Maker via a Firewire cable. Than convert it to NTSC on your machine using software like Nero... do a search on Google for converting software. Or just watch it on our computer in PAL format, most computers do that... For this step I use a separate camcoder that has a passthrough feature. The VCR connects to it and the camcorder connects to the computer via Firewire.
4) send the PAL tape to a specialized shop for conversion. They normally charge $30-$40 for a regular 2h VHS tape.
Posted on Jan 27, 2009
Sony SLV-ED818 black and white picture
Is the TV a USA model? In which case it will use the NTSC system of colour and not the PAL one. You will need to check if the TV can be switch to PAL system for DVD or if the DVD can output it as NTSC. Or you need a convertor box.
Jan 23, 2013 | Sony SLV-ED818 VHS VCR
Dvd or video only produces black and white pictures
just go to your dvd seting and chose the output setting you will see ther an 3 diferent output NTSC-PAL-AUTO chose auto if automatic output doese not work call a service center for your dvd.
Aug 11, 2010 | Sony SLV-D950 DVD Player/VCR
I can only record and play back in black and white.
siri,
for the black and white screen output of your DVD and VCR.
1) for DVD player: using remote control locate "setup" button and click.a dialogue box should appear indicating " audio setup" video setup" etc.....
2) select and scroll to "video setup". in video setup there should be an option to choose "AUTO" "PAL" or "NTSC"
3) choose "auto" then check if any change in screen color.
for VCR, locate a switch or button indicating "PAL" "Auto""PAL SECAM" "NTSC". same with the dvd choose and select "auto"
note: if you still have the manual for both VCR and DVD check the instruction with regards to video color setting.
cheers,
mark
Jan 15, 2009 | Philips Magnavox DVD/VCR Dual Player
No color
Please set your TV on Auto Color system to get colors on VHS and DVD.
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Vcr only plays in black and white
Hi Ryana,
Check if the recorder is set to output in 'S-Video' or 'SuperVideo' mode, if your TV doesn't understand S-Video you'll get a grainy B&W picture. The VCR should be set to output in PAL for the UK and most of Europe.
Hope this helps
Andy
Jun 26, 2008 | Philips DVP620VR DVD Player/VCR
No video in my philips dvd622
The black and white picture is caused by only 2 things.
  1. You are trying to play back an NTSC disc in a PAL dvd player (or the other way around)
  2. Your DVD player is set to NTSC when it should be set to PAL (or the other way around)
You will find options for setting PAL or NTSC in the setup menu under Video.
Apr 03, 2008 | Computers & Internet
NO color output
Jul 21, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
Video output showing black and white display
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Jan 13, 2018 | Sansui VRDVD5000 DVD Recorder/VCR
DVDs Play in Black and White
this may be the problem with your dvd player
Feb 14, 2007 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Televison & Video Logo
207 people viewed this question
