Question about Samsung LN52A750 52" HDTV LCD TV
MY HDMI ports on my Samsung 52 inch 750 LCD Touch of Color TV do not work. None of the 4 ports will get a signal from the Direct tv HD receiver. I switched to componet source and the signal is fine. I think it may need a new motherboard. What is your opinion?
    Sergeant:
  • 252 Answers
No it may mean that you need a new tuner
Posted on Aug 05, 2010
How do I change my service from analog to H D?
Most LCD tv's built in the last 4 years are HD compatible. Most cheaper brands tv's are 720 HD and some are full HD 1080 a little more money. Since their is no more analog broadcast as June 2009 all tv's manufactured around 2006 started incorperating the digital tuner (DTV) along with the analog so that the tv would still receive analog broadcast while the digital transistion was ongoing. All tv's with a Cathode Ray Tube (glass picture tube) are not HD compatible. First you will have 1 or 2 ports on the tv ethier on the side panel or rear panel of the set. They a marked HDMI 1 HDMI 2 or HDMI A HDMI B. If you have these ports your set is Hd Compatible. You may also need to upgrade your cable or satelllite equipment and subscribe to a HD package to be able to get HD service. You will need a HDMI cable to connect your cable or satellite receiver to the HDMI port on you tv. Call your local cable or satellite provider for options to upgrade to HD. Most over the air broadcast stations depending on your area transmit some stations in HD free of charge. A good quality outdoor antenna works best to give you stable signal. You may need to change the settings of the tv as some sets default to the 480i this is the standard digital signal.
Sep 10, 2014 | Televison & Video
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
I have had a 52" LG TV for about 17 months. I connect several devices (XBOX,CABLE,PC) through a receiver to the TV via HDMI. it worked fine all the time but now all of a sudden all I am getting is a no...
Did you change the HDMI cable? If so, you should check to ensure you have the cable installed so it is running the right direction. It may seem hard to believe but some HDMI cables only allow the signal to run in one direction.
Aug 05, 2014 | LG M5203CCBA 52-inch LCD Flat Panel...
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
Aug 12, 2011 | Samsung LW32A33W 32 in. HD-Ready LCD...
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
hi,
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
ok
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
Insignia 37 inch lcd inputs not working except for hdmi inputs
TV when hooked to Direct TV by HDMI will not work, it must be hooked by RCA cables. I now have 1080i rather than 1080P. The HDMI cable and the direct TV box has been changed. What can the problem be?
Jul 01, 2009 | Televison & Video
I have a 37" Sony Bravia KDL-37XBR6 that I purchased in July 2008. I also have a Time Warner HD cable box that also has a built in DVR. The HD cable has been connected to the HDMI 1 port. It worked just...
Hello, There is an update for your TV at Sony Support and I would strongly  recommend to call Sony Support to update your TV as firmware updating firmware is risky job for novice and TV firmware can be damaged and TV will shut down.
Jan 10, 2009 | Onkyo TX-SR605 Receiver
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Samsung LN52A750 52" HDTV LCD TV Logo
228 people viewed this question
Jerry Greenberg
Jerry Greenberg
