Question about Akai Televison & Video
After turning the power on, it is necessary to turn the power on and off about three (3) or four(4)times before the channel will appear on the screen.
  • ellenw37 Aug 05, 2010
    Thanks for the help.
  • Akai Master
  • 11,800 Answers
The power source is close to complete failure - the electrolytic capacitors have aged and dying . They need to be replaced ASAP,while it's a cheap and simple fix,  or the source will catastrophically fail, most likely killing the tv as a whole.
Posted on Aug 05, 2010
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
Vauxhall corsa says SAFE how do i unlock please
Here is how you unlock it:
1) Turn radio off
2) Start engine
3) Press and hold down AS button
4) Turn On radio WHILE holding down the AS button until there is a beep
5) Dial the code using the 1, 2, 3, 4 keys (eg: 1234 would be 1 once, 2 twice, 3 three times and 4 four times)
6) Press and hold AS button for approx 5 seconds
Mar 02, 2011 | Car Audio & Video
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
LaserJet M4345 MFP Printer: how to cold reset in HP LaserJet M4345 MFP...
walid_sayed@hotmail.com
To perform a cold reset
1 Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. This might take up to 20 seconds.
3 Press 3 four times until COLD RESET appears on the control-panel display.
4 Press 6 one time. The MFP continues its initialization sequence.
May 07, 2010 | HP LaserJet M4345 MultiFunction Printer
I cannot figure out how to program my scanner to the fire frequency.
To program any known frequency into your BC72XLT, power the scanner ON, and then:
1. Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears.
2. Use the number keys and to enter the frequency (including the decimal point) you want to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency.
• The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475.
• When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning 2 seconds after the end of a transmission before scanning proceeds to the next channel. To turn the function off or on, press Func + Dly.
• If you enter a frequency that has already been entered elsewhere, the scanner sounds an error tone and displays the channel that was duplicated. If you entered the frequency by mistake, press then enter the correct frequency. To enter the frequency anyway, press E to
accept.
4. To program the next channel in sequence, press E then repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 16, 2010 | Uniden BC72XLT Handheld Scanner
How do i program the control to the converter box!
Try these steps: 1. Turn on your TV and change it to channel 3 or 4. 2. Press the power button on your Insignia Remote control. The converter light will be turn on in stand by mode (the red light appears). Press the power button again, the blue light will be on. 3. On your Insignia remote control, press the menu button. 4. A menu items appear, navigate to the autoscan item to scan channel.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
WHY DO I HAVE TO PUT MY TV ON CHANNEL THREE TO WHATCH A MOVIE
Both previous solutions are correct, but there may be another step. Sometimes the switches are hard to see because they are small and hide near the antenna in and out jacks. But some newer VCR's don't have a selector switch at all. To choose between channel 3 and channel 4 output, you need to use the VCR's setup menu. So if you can't find a switch like the other posters mentioned, check the VCR setup menu for an output channel selection. Then, as previously mentioned, make sure that the VCR output channel is added to your TV's channel lineup.
If you find a solution not exactly what you need, or not clear enough, please post a followup before giving negative ratings (thanks for trying or not appropriate). While those of us who take time to answer questions and try to help here don't get paid, we are more likely to be taken seriously if our ratings stay up. At the very least, both of the previous solutions should have been ranked helpful, because they are correct and should have given you the advice you needed.
Oh, one last thing: In posting, using all capital letters makes it hard to read, and is the equivalent of shouting. Please turn off the caps lock key. Thanks!
Mar 05, 2009 | Daewoo DTQ-20N3FC 20" TV
BC72XLT
Here is the directions to store frequencies in your scanner:
Storing Known Frequencies
Into Channels
to store.
Notes:
Operation 2 seconds after the end of a transmission before
accept.
Dean
Rollin CBs
Feb 19, 2008 | Uniden BC72XLT Handheld Scanner
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Televison & Video Logo
11 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
