Question about Zebra TLP 2844-Z Thermal Label Printer
The Zebra TLP 2844 stops printing and indicates a red light after 1 or 2 labels.
Bubbabear64
  • 2794 Answers
SOURCE: Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Posted on Jul 29, 2008
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
  • 185 Answers
SOURCE: how to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Posted on Dec 20, 2009
ozztech
  • 285 Answers
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
Posted on Nov 25, 2010
I have a Zebra 2844 CTP printer: Recently changed from 2x1 hard labels to 2.25x1.25 sticky labels, and now my printer will not print my category on the label, and I get an additional blank label printed,...
The printer may need recalibrating.
Switch off - hold down feed button and switch on when indicator flashes release button.
Printer will fedd then print a configuration label. Should now be OK
Jun 03, 2011 | Zebra Eltron TLP 2844 Thermal Label...
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
These 2 links will help you troubleshoot the problem:
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Error triying adjust labels on zebra tlp 2844
Try to calibrate it: turn off your computer, press the button and turn on, release the button and let progress labels.
Oct 20, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844 Desktop Printer
make sure you have selected the correct media in the printer driver. The tracking mode has 3 options, (1) Web Sensing (Cut Labels), (2) Mark Sensing (Black marks on back of liner) and (3) Continuous . In your case select continuous. It sounds like the printer is in the wrong media mode and is feeding labels looking for a mark or gap and when it doesn't find one it flags a media error.
Aug 15, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra tlp 2844 trouble
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
Aug 02, 2008 | Zebra R2844-Z Label Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
364 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
