Question about Poulan Garden
Poulon chain saw model 2175 no spark. What to check?
    Brigadier General:
  • 4,088 Answers
Remove the starter assembly and left side cover to expose the flywheel and ignition module after trying a new spark plug gapped at 0.020". Remove the ignition switch wire from the module and try for spark again--if still nothing, use a thin business card for a gap gauge between the flywheel magnets and the module poles. Loosen the mounting screws, let the module contact the magnets through the card, then tighten the screws. Try for spark again--if still nothing, replace the module. Use the above procedure to install the new part. Hope this helps!
Posted on Aug 05, 2010
How do I remove the clutch cover to adjust chain on my Poulon Pro Chainsaw?
There should be two nuts on the side loosen but do not remove the on the front of the saw is the adjustment screw tighten chain slightly pu sh bar down lightly on ground pullchain up to check for right tension while still pushing down on ground tighten two nuts on side of saw you are all set
Nov 08, 2016 | Poulan Garden
Looking for a sprocket/chain cover ( has two holes) for a Poulon 445 bow saw. Where can I find?
Ebay will probably be your best bet. Search for "Poulon 445 chain cover".
Feb 01, 2015 | Garden
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
How to adjust carb. on a poulan chain saw 38cc model 2175
If the carb is adjustable, it will have two small screws on it ( maybe covered with a plastic cap) One is low speed and the other is high speed. Adjust very little at first.
Sep 24, 2014 | Garden
How to adjust a poulon pro chain saw 46cc 20" chain tighting
First, I'd read the manual if in doubt. No matter the type of adjuster, tool-less or not, you loosen the bar nuts, tighten the adjuster until the chain just touches the bar on the bottom (while holding the bar nose up) then tighten the bar nuts. Chain should move easily.
Re Poulan chain tightening. Be sure it's oiled and sharp, of course.
Aug 20, 2014 | Poulan Pro Chain Saw 46cc 20"
I have a poulon p4018wm chain saw that runns but after it gets hot you have to wait for 30-45 minutes before you can start it again
if it gets too hot say from dull blade or not enough lube on chain it can cause gasoline to change to a gas
May 18, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Saw won't start
Remove the spark plug and check for a snappy, blue spark. If nothing or very weak, try another plug. If still nothing, remove the switch wire from the ignition module. If still nothing, replace the ignition module. Use a thin business card to set the gap and have the magnets under the module poles. You should have spark at this point. If still won't fire, but has spark, try spraying some starting fluid into the plug hole, install the plug, and try to start. If you get a couple of pops, then check the fuel lines, fuel filter, and make sure the screws are tight on the carburetor. If still won't run, you may need to clean and re-kit the carburetor. Make sure the air cleaner and muffler are not plugged. Hope some of this helps!
Apr 09, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Cannot tighten the chain bar
Make sure the bar is positioned on the bar adjusting pin before you tighten cover. Adjust tension with bar adjusting screw, then tighten bar bolts.
Mar 25, 2009 | Poulan PP4218AV 18" Chain Saw
Garden Logo
62 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
