Question about Yamaha 2300 Watt Generator - EF2600
Can you help me? I have generator yamaha ef 2600. Generator normally running about 3 minutes then rpm comes unsteady and gen stops. Moreover at load 2kW gen immediatly works unsteady and stops. Without excitation (condenser moved out) engine works properly. Diods on rotor checked, oil changed, valves grindered, clearence set according to manual
  • brendonmarr
    brendonmarr May 23, 2012
    can you give clearance setting
  • Paul Julius Jan 08, 2017
    I have a EF2600 with the same problem...how do i fix it..
    Scholar:
  • 142 Answers
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
  1. If smoke comes out of muffler - the input air is not sufficient. Try to clean or change air filter (cleaner).
  2. If no smoke, the fuel is not enough. The reason may be the mechanical governor, or the fuel supply to it, fuel filter/strainer etc.
Posted on Aug 05, 2010
Output of generator is lower voltage than it should be usually 440v now 395v? reasons?
possible that the rpm of the gen set is lower than normal
there is an adjustment screw that adjusts the spring tension for the governor and it can be adjusted to bring the voltage back to normal
Note here--- if you run the set with a load of around 1/2 capacity set the voltage to on the 440 volts
if you run it at near capacity set it above voltage (445) because as it comes under load the rpms drop and the voltage comes back to normal
Nov 08, 2016 | Electrical Supplies
Model ef6600de. How do I decrease rpm?
Search Results
    [PDF]EF4000DE, EF5200DE, EF6600DE, YG4000D ... - Yamaha
    www.yamahamotorsports.com/assets/.../0/LIT-19626-01-15_1425.pdf
    Generator. LIT-19626-01-15. 7WV-28199-11. EF4000DE. EF5200DE. EF6600DE ...This manual will provide you with a good basic understanding of the operation and .....card listing your Yamaha model name, engine ... rpm. NO OTHER ADJUSTMENTS NEEDED. ENGINE OIL: IDLE SPEED: ..... Electric Starting Model:.
    [PDF]yamaha generator theory & diagnostics guide - Gen-Tech
    www.gen-tech.net/fullpanel/uploads/files/theory--diagnostics-guide.pdf
    Yamaha Generator Theory and Diagnostics Guide .... Conventional EF6600DE . ...models with Smart Throttle) do not rely on rpm to ... unit manages functions such as AC power modifica- ... tions means higher fuel economy at lower outputs.
    Yamaha Motor Canada :: Products :: Power Equipment ...
Dec 25, 2015 | Yamaha Electrical Supplies
Ef 2400 Is Yamaha generator Over Revs
Take it to a dealer, there is a solid state module inside that controls the charging and idle, also a wiring diagrams are available with owners manual, go to Yamaha web site also..
Apr 12, 2017 | Yamaha EF2400iS Portable Generator
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
Yamaha Portable Generator EF 1000 iS won't start. Last time I ran the generator (several months ago) I let it run until it was out of gas. Yesterday I filled the tank and started the generator. It...
Try cleaning the carb out,(hog wash carb cleaner I use) the float may be stuck or the needle & seat.You may need a rebuild kit for the carb,about 12 bucks.hope this helps
Jan 09, 2011 | Yamaha 2500 Watt Industrial Inverter...
The coleman voltage generator for 250 kva gen set
Well I assume that this generator is NOT three Phase, and delivering 440 Volts? in that case, that reading is what is called and "Open Circuit" reading, with a full load, that reading will/should come down to the nominal voltage of 250 V (+/- 10%) This generator is a 250 V AC unit? If this is so then it is operating correctly? It is 5kw UNIT. using a digital multimeter due to it's large input impedance it will often give erroneous readings if NOT loaded down with the correct.any. load.?
Mar 02, 2010 | Coleman Powermate Powermate 5000W...
Gardian Generator transfers while doing whisper test
How does it do for RPM's with light load? Try turning off some load so when it transfers, you can see if you're overloading it. To much load could bring down the speed drastically. If it holds speed with 3/4 load, that's probably the problem. If not, try half load. You need to match the load watts to the Gen KW.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 01, 2009 | Electrical Supplies
Yamaha ef1000 will only idle and produce 12 vac
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
Dec 17, 2008 | Yamaha 2500 Watt Industrial Inverter...
Low voltage
Most generators use a flyball type governor within the engine to control rpm; also there is a voltage regulator that tries to maintain voltage at about 115v. The voltage regulator varies the voltage to the armature increasing /adjusting magnetic force. Use a meter with htz or freq setting to adjust engine governor to 60 cycles. When the generator is producing 60 cycles, the engine should be turning 3600 rpm, max power range. At 3600 rpm the voltage should be 115 to 120 volts. Loading the generator will cause governor to try to maintain 3600 rpm. Check engine manual for proper adjustment of gonvernor and linkage. The governor mech should last the life of the engine, however governor system does wear out. Expensive repair. enjoy
Nov 26, 2008 | Yamaha Electrical Supplies
Yamaha 2300 Watt Generator - EF2600 Logo
601 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
