Trying to connect a lexmark 3500 4500 to an acer1352lc cannot retreive icon which appeared at bottom right of screen
  • 487 Answers
Disconnect printer. Uninstall
reinstall as normal . this should help. no problems normally.
Lexmark also has all drivers
Posted on Apr 26, 2008
How do i get icons at bottom screen in i mac
If you want to add the application icons to the bottom of the screen (or Dock) there are a couple of ways to do this.
1.) Open a window in Finder and go to 'Applications', simply drag the application you want to appear in the Dock toward the bottom of the screen and release when the app icon is where you want it to be.
2.) Launch the application you want to appear in the Dock. When the app is running, the icon will appear in the Dock on the right side, to make it stay there even when you quit the app, simply right-click (if mouse supports it) or control click and from the pop-up select 'Options' and chose 'Keep in Dock'.
You can move the icons around in the Dock by click and holding on them and dragging them around to the location you want... and to remove an icon from the Dock just drag it off the Dock into the main area of the screen and release.
Sep 22, 2014 | Computers & Internet
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Flashing message says: Cartridge error: consult user manual.Error 1203. Power on and off works. Otherwise will not change from that message. Trying to send fax. Will not let me copy, scan,...
A "No communication" dialog appears when you try to print or scan.
What to do
If you are printing wirelessly, launch the printer's Wireless Setup Utility and follow the instructions.
If you are connected by USB or ethernet, try one or more of the following:
  • - Ensure the cable is secure at both ends.
  • - Disconnect the printer power suppy from the wall outlet, wait 10 seconds, and then reconnect it.
  • - Restart the computer.
  • - Make sure the correct port is selected in the Properties screen. To do this:
      1. Go to Start, Settings, Control Panel.
      2. Double-click on the Printers folder.
      3. Right-click on the printer icon and select Properties.
      4. In the Properties screen, click the Port tab.
      5. Ensure that the printer port is set to one of the USB port options; see below.
        Click here to view an enlarged version of this image.
      6. Select the port and click OK.
      7. You may need to reboot the PC for the change to take effect.
NOTE: The printer icon may not be displaying in the notification area (the "systray"). Once the port is correctly selected, the icon should appear there.
Still have questions?
Please contact Lexmark Technical Support for additional assistance. When calling for service you will need to know your printer model type and serial number.
Please call from near the printer in case the technician asks you to perform a task involving the printer.
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
The printer turns on and I have everything
Sounds like you need a driver downloaded or re-install your soft ware. Make sure ink cartridges are installed properly.
Feb 27, 2010 | Lexmark X2690 All-In-One InkJet Printer
Device is busy error
Check on the bottom right of the screen you will see a small printer icon.
Double click on the icon. That will open up the Print Queue.
Look at the print jobs. If one job shows as Spooling, click on the job and then delete it.
Don
Jan 18, 2010 | Lexmark Office Equipment & Supplies
Tried to view photos through computer, the files were not opening, when we put it back in the camera the card is asking to be format before use ??? Have we lost the files?? can we retreive them somehow???
When you removed the card from your computer, did you use the "safely remove hardware" icon in the bottom right of your computer screen? Your only recourse now may be to take the card to a store like Walmart that has a Kodak picture kiosk. Insert your card and your pics may appear. If so, you can print them or even make a cd of them.
Jan 01, 2010 | Cameras
Lexmark z600 will not print documant
Sounds like the install was corrupt.. Try uninstalling and re-installing your software. Make sure your drivers are up to date also. You can download them from the lexmark website.
Jan 06, 2008 | Lexmark Z600 InkJet Printer
Epson stylus C66 doesn't print
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Dec 16, 2007 | Lexmark JetPrinter Z55 InkJet
Lexmark 1185x
No Communications Error When Trying to Print or Scan ID:ENUS27546 null.gif null.gif null.gif
What you will see A"No communication" dialog appears when you try to print or scan. What to do Make sure the correct port is selected in the Properties screen. To do this:
Nov 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HELP SCANNING OR FINDING A SELECTION TO SCAN
There should be an icon in the system tray (bottom right corner of your screen). It is white with different color blocks on it. If you hold your mouse pointer over it it says something like "Lexmark Imaging Studio". Right click on it and choose "Lexmark 1200 Series All-In-One Center". This will start the scanning application.
Sep 11, 2007 | Lexmark X1240 All-In-One InkJet Printer
29 people viewed this question
jasbo
jasbo
