Question about Apple iTunes
ITunes takes forever to load on my Windows 7 PC (e.g. 10 minutes) - what can be done to fix this?
    Scholar:
  • 166 Answers
Resolution Create a New User Account When troubleshooting a variety of issues, it can be useful to determine if the issue affects a specific Windows user account or all accounts. Follow the steps below to create a new user account in Windows Vista or Windows 7:
  1. From the Start menu, choose Control Panel.
  2. Open Add or remove user accounts (If using the Classic View in Windows Vista, open User Accounts. Then open Manage another account).
  3. Select Create a new account and follow the instructions to complete the account setup process.
  4. Once the new account is created, choose Log Off from the Start menu.
  5. Log into the newly created user account.
  6. Open iTunes and determine whether the issue you were experiencing persists in this new user.
If you see the same issue in the newly created user account, proceed to the System-wide troubleshooting section below. If you do not experience the same issue, consult the User-specific troubleshooting section below.
User-specific troubleshooting If your issue only happens in one particular user account, some of the suggestions below may resolve the issue. Before proceeding however, you'll need to make hidden files and folder visible in Windows. Follow steps 1-5 in iTunes for Windows in Windows Vista doesn't open after upgrading.
  • Remove iTunes Plug-ins
    Third-party iTunes plug-ins can cause many issues, particularly if the plug-in has not been updated to be compatible with new versions of iTunes. iTunes plug-ins are stored in the following location:
    C:UsersusernameAppDataRoamingApple ComputeriTunesiTunes Plug-ins
  • Remove iTunes Preference files
    Some of the files that iTunes uses to store settings and preferences may be unusable and cause issues. iTunes has two folders where preferences are saved. Move one of them to the desktop and test to see if the issue persists. If it does, move it back and remove the second folder. The location for the two preference folders are:
    • C:UsersusernameAppDataLocalApple ComputeriTunes
    • C:UsersusernameAppDataRoamingApple ComputeriTunes
  • Create a new iTunes Library
    1. Hold the Shift key while opening iTunes. You will be prompted to Choose iTunes Library.
    2. Choose Create Library to create a new one. In the following window you will be prompted to select a location to save the new iTunes Library.
    3. Click Save. iTunes will open the newly created library. After closing iTunes, you can always select the original library by using the Shift key when opening iTunes.
  • Recreate your iTunes Library
    If you iTunes library has become unusable, rebuilding it as described in How to recreate your iTunes Library and Playlists may resolve the issue.
Check for content files with issues
Sometimes a certain audio file can cause iTunes to quit unexpectedly or stop responding when it is analyzing gapless playback information. To determine which file(s) may be cause the issue follow the steps below:
  1. Quit iTunes.
  2. Navigate to the iTunes folder:
    • Windows Vista - C:usersusernameMusiciTunes
    • Windows 7 - C:usersusernameMy MusiciTunes
  3. Move the iTunes Library.itl file to your desktop
  4. Open iTunes. You should not see any content in iTunes.
  5. From the File menu, choose Add Folder to Library.
  6. Navigate to the folder where your music is located. Typically this is
    • Windows Vista - C:usersusernameMusiciTunesiTunes Media
    • Windows 7 - C:usersusernameMy MusiciTunesiTunes Media
  7. Note: This folder may be called iTunes Music if it was created with iTunes 8 or earlier.
  8. Choose an artist, album, or single song to add the to the library
  9. Wait for iTunes to successfully add the songs to your library and perform the gapless playback scan.
  10. If successful, continue adding back more songs to your library.
  11. If there is an issue with one of your files, you will notice your issue reappear after you attempt to add it to the library. At this point you should repeat these steps being careful not to add the files that cause the issue to occur.
System-wide troubleshooting When troubleshooting system-wide issues with iTunes, there are a few different suggestion to try.
  • Check for viruses
    Windows viruses can interfere with a variety of computer functions including iTunes. Make sure that you have current anti-virus software installed with updated virus definitions and use it to scan your system.
  • Check for anti-virus and/or Internet security software
    Internet Security software itself can sometimes cause iTunes to quit unexpectedly. Try disabling the Internet Security software temporarily or exempting iTunes from any active scanning done by such software. If this resolves the issue, check with the maker of the software for an update to the software or its virus definitions. See the following article for more information: iTunes for Windows: Troubleshooting security software issues.
  • Conflicting processes
    Sometimes other programs and start-up items can conflict with iTunes, look at the following article to troubleshoot such conflicts:
    Using MSCONFIG to troubleshoot conflicts in Windows Vista and Windows 7
  • Removing iTunes configuration files
    Removing unusable configuration files that iTunes uses can resolve launch issues. See "iTunes for Windows Vista or Windows 7 doesn't open after upgrading" for information.
  • Check the iTunes and QuickTime installations
    An improper installation of iTunes or QuickTime can contribute to a variety of issues. Follow the article below to learn how to completely reinstall iTunes and QuickTime:
    Trouble installing iTunes or QuickTime software in Windows
  • Update the drivers on your PC
    Having outdated drivers on your computer can cause strange behaviour with iTunes, QuickTime, iPod, and other applications. See this link to update the drivers on your computer.
Posted on Aug 18, 2010
The quick wash takes over an hour any suggestions how to make it quicker?
The manual says wash number 5 takes 60 minutes the only shorter cycles are numbers 9 & 10 which take 55 minutes but they are cooler washes for wool and silk with a spin speed of 800rpm the number 5 has a spin speed of 1400rpm.
Apr 26, 2015 | Hotpoint Aquarius WDL540P White 60 cm...
Ipod classic won't sync with itunes 10
Restarting your computer is often the solution when your iPod fails to sync with your iTunes music library. But if this fails, there are other troubleshooting steps to take.
Recharge your iPod via a USB cable connected to your computer or AC adapter. b> Click the help menu in iTunes and check for updates. Follow the onscreen prompts to download and install the latest version of the software. Open the new version of iTunes. Click the name of your iPod in the source list and check for updates under the summary tab to update your iPod. Attempt to sync your iPod with iTunes. Slide your iPod's hold switch to the hold position and then to off. Press and hold the menu and center buttons simultaneously until the Apple logo appears to reset your iPod. Open iTunes on your computer and reconnect your iPod to try to sync it with iTunes. Restart iPod service b> Close iTunes and make sure your iPod is disconnected from the computer. Click the 'start' button. Click 'run' if using Windows XP. Type 'services.msc' in the run box in XP and in the search box in the start menu in Windows 7 and Vista. Press 'enter.' Scroll through the list and double-click on 'iPod service.' Click the 'stop' button and leave the properties window open. Connect your iPod to the computer. Open 'my computer' or 'computer' and look for your iPod listed in the devices with removable storage section. Click the 'start' button in the iPod Service's properties window. Open iTunes to attempt to sync your iPod. Close the iPod Service's properties window once your iPod has finished syncing. Resolve "Original File could not be Found" Double-click the name of a song in the iTunes program that failed to sync to your iPod. Click 'yes' or 'locate' to the message asking you if you want to locate the file. Navigate to the folder or directory location where the song is stored on your computer. Double-click the song file to select it and add it back to iTunes. Reconnect your iPod to the computer and open iTunes to restart the syncing process. Some songs in iTunes won't copy to iPod http://support.apple.com/kb/TS1420 iPod classic Troubleshooting Assistant
http://www.apple.com/support/ipod/five_rs/classic/
Apr 12, 2013 | Apple iPod MA446LL/A MP3 Player
Takes forever to load the OS
Sometimes windows is installing or configuring updates that takes windows a long time to boot. WebRepOverall ratingThis site has no rating(not enough votes)
If its not due to installation of a program or configuring updates then the only reason left is windows internal errors.
Perform the following tasks to fix this problem:
  • Fix Damaged or corrupted registry
  • Fix Missing or damaged DLL files
  • Scan with Anti-virus
  • scan with Anti-Spyware
  • Delete Temporary internet files
To fix this problem instantly use Intel Software Partner Reginout.
Dec 13, 2012 | Toshiba Satellite L775d-s7206 1.40ghz Amd...
MY 3 YEAR OLD PACKARD BELL LAPTOP TAKES UPTO 3 MINUTES TO SHUT DOWN
You could try removing items from startup. Start > Run > type MSConfig > Startup. Uncheck items you don't want to load. This will make your PC faster. This can also be done with CC Cleaner if you haven't done so already.
Aug 27, 2012 | Packard Bell Computers & Internet
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
Dec 07, 2017 | HEWLETT-PACKARD Black 20" TouchSmart...
Taking 7 minutes to boot up
You may have a virus infected. I would get it checked out or try to trouble-shoot yourself.
Please follow this guide for how to install a good anti-virus program that is free forever.
http://www.fixya.com/support/r5317428-actually_free_antivirus_software_windows
If this doesn't speed things up please write back.
Jul 16, 2010 | eMachines T5274 Desktop PC
DVD drive Read problem in my Dell Dimension 3000
Make sure you have any and all Windows 7 updates from Microsoft, along with any updates for your DVD drive for use with Windows 7. Some components work fine using Vista SP2 drivers, but some will need an update to work with Windows 7.
This Microsoft site might help verify if your DVD drive is compatible with Windows 7:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Feb 12, 2010 | Dell Dimension 3000 PC Desktop
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Apple iTunes Logo
3,580 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
