Question about IO Magic Corporation IDVD8PE (788069008556) DVD±RW Dual Layer Burner
How many dc voltage can the IDVD8p work? - IO Magic Corporation IDVD8PE (788069008556) DVD±RW Dual Layer Burner
5v 2amp i got this off io magic corp. web site under there accesoris
Posted on Feb 08, 2011
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
How do I fix my power adapter?
Could be the capacitors that filter the final D.C voltage in the power apadter . If the capacitors fail the D.C voltage would have 50 or 60 hertz hum on it. If a diode has failed it could also cause a more severe pulsing of DC voltage. A oscilloscope would show up if the DC is being distorted but I do not know where you would get access to one. A repair shop maybe ?
Jul 02, 2015 | Crosley Audio Players & Recorders
Broken DC/DC converter
It is probably a shunt fed switch mode power supply with a short circuit chopper transistor.
Jun 15, 2014 | Computers & Internet
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
Yukon 2.5 x50 nvrs tactical night vision rifle scope, works fine but making a strange processing noise when on?
Hello, don't worry about it. It is HV to the image intensifier tube. The battery voltage goes through control circuit then to ccfl inverter (here is were dc voltage is switch on and off and switch dc voltage is step up by toroid coil that has two input and only two out puts). By impulsing the coil with two different switch dc voltage on the input this make the current lag the two different phase voltage by 90 degrees. Here is where the strange noise is coming from. The toroid coil is encased in iron case and if half of this iron case is loose, it makes case vibrate so the noise.
Now, the voltage come out of the toroid coil is switching dc (one could call it AC because that what AC voltage is, it switch between positive to negative) this voltage is about 300 to 900 switching DC voltage. This voltage will be applied to a 1/2 wave voltage multiplier (this voltage multiplier with have anywhere four four stages to 10 stages depend on what the input voltage to multiplier is.
Low the voltage out of the ccfl inverter the more stages the multiplier will have.
Now, the voltage multiplier will double the voltage per stage to need image intensifier tube voltage of 12000 to 45000 volts---DC switching or AC what ever one wants to call it. This voltage will bit you but it doesn't have a lot current associated with it, the current would be in the 10 to 15 ua (micro-amps) 1/10X6 amps.
Now, you know. GB...stewbison
Sep 24, 2011 | Yukon Optics
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
My nootbook do`s not read io magic idvd8p dvd problem:
It might be the cable.Please change the cable to see if it works.
I hope this solution has been successful.
Sep 26, 2010 | Computers & Internet
DC testing
No, you can't use an Ideal 61-065 tester to test a car battery. It is only for 100 volts AC/DC to 600 volts AC/DC.
A meter like this will work:
http://www.a1components.com/itemdisplayn.aspx?item=11307
Actually, the easiest way to test a car battery without a meter is to turn on the lights. If the lights shine bright like they are supposed too for a minute or so, the battery is maintaining the correct voltage.
Feb 20, 2010 | IDEAL 61-065 Voltage Tester
BA745
yes bad bord so cheap on these u can kick bass out like u wanna best bet referb kilspsh on ebay 70 bucks bass on them rocks ok
Jan 16, 2008 | Boston Acoustics BA745 Computer Speakers
IO Magic Corporation IDVD8PE (788069008556) DVD±RW Dual Layer Burner Logo
368 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Falling star
M_Butkus
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
