Question about 474L Avital 4Button Transmitter 434 MHz 266 Codes
I cant take my remote starter off of sleep mode
Our Sony TV at work will not give us the option to turn off sleep mode permanently.
Go into settings, there is a option to turn the sleep mode on or off.
Oct 12, 2016 | Sony Televison & Video
Does this remote have sleep mode
No idea of what remote you have but some TVs allow you to access the sleep function via the menu structure.
Dec 08, 2014 | Televison & Video
Cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
Prostart remote starter is in sleep mode. How to get out of sleep mode
To get an iBook out of sleep mode, you can hit any button on the computer. ----------------------------------------------------------------------------
Car Key Programmer
Nov 22, 2012 | Cars & Trucks
Kenmore 70121 air conditioner
There should be a sleep mode button on the remote. Press this then pres ok/enter.
Note: In this "MODE" the selected temperature will increase by 2 degrees F 30 minutes after the mode is selected. The temperature will then increase by another 2 degrees F after an additional 30 minutes. This new temperature will be maintained for 7 hours before it returns to the originally selected temperature. This ends the "Sleep" MODE and the unit will continue to operate as originally programmed. The "Sleep" MODE program can be canceled at any time during operation by pressing; Sleep MODE, "On/Off", "Fan Only" or the "V//X" buttons, on either the Control or the Remote. "Time Delay Stop" limit reached will also end "sleep" MODE.
Jun 01, 2012 | Kenmore Heating & Cooling
Since changing to freeview in april i no longer need the use of the original tv remote as the new remote is being used. my problem now is i cant find how to set the tv to sleep mode shud i fall asleep...
Your new FreeView remote will only support the essential functions of your tv. In some cases that's limited to volume up and down, sound mute and on/off only, but often they can do more. Sleep timers are rarely supported.
Your fix is to either set the sleep timer on the old remote, or to buy another fully programmable learning remote control, where you can customise almost every button and use your old remote to teach the learning version its tricks.
Jul 22, 2011 | Televison & Video
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
Trying to use sleep mode, no manual or original remote
do a google search on the model of your tv..and you will find the original remote available most of the time for only a few bucks..........
Feb 03, 2008 | Philips 55PW9363 55" Rear Projection...
474L Avital 4Button Transmitter 434 MHz 266 Codes Logo
247 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
