Question about Garden
HUSKIE 14.5 42 IN MODEL 136M673G131 DECK JUMPS WHEN YOU START THE ENGINE AND WILL NOT TURN OVER
I put on a deck belt for my huskee 42 and the engine wounld trun over
A safety feature on many newer mower decks and some older ones is: that the engine will not start if the PTO is engaged. Also there is a deck clutch (or deck break) that prevents the deck pulleys from turning. Make sure it is connected properly. It's under the deck and has a big spring on it. If the wire it is attached to has lost tension or is slack for some reason, the deck break will come on and prevent the tractor from starting. It's not usually an engine problem, but a friction problem. Because the deck pulleys are stopped by the break the high amount of friction is to much for the engine to turn over. This usually is the problem if you have the PTO ( deck engage lever) on before you try to start the engine.
I hope it's just this. :)
Aug 20, 2016 | Garden
Gas gauge problem
check all wiring around starter to see if you pinched 1 or 1 is grounding against starter.
can not add more because you not state make an model
Aug 14, 2015 | Cars & Trucks
Husqvam zero turn deck belt jumps alot at idle
if deck belt has a lot of burn spots on belt it will jump like crazy
Sep 17, 2014 | Garden
My 18 hp cub cadet deck belt continually jumps off pulley
There are MANY pulleys on that deck. Which pulley are you talking about?
Jan 24, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Does Craftsman Model 917.272461 have a low oil shut down sensor?
Sounds you added oil for late. Can you turn engine by turning engine
on the screen, top of engine?
Aug 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Huskie 21K46 is hard to start first thing during the day and after sitting for awhile.
check and be sure the air filter and fuel filter is clean. if they are you may consider taking the carburetor off and cleaning it. it sounds like a fuel problem that involves several things.
Oct 16, 2017 | Husqvarna Garden
Have a Huskie riding mower,will not start. Turns but does not engage.Had a backfire, smell the gas, checked the filter, fine. Just wont turn over.
Check and see if you have spark if so then check and see if the safety switches are ok you might need to replace one
Dec 08, 2011 | Garden
I recently bought a 2002 craftsman 17.5 hp, 42" cut deck mower.(Mdl# 917272670) It hesitates after you turn the key to start. When I turn the key to start position, choke on, you hear an initial...
Your starting problems sounds just like the overhead valves need to be adjusted. They work in timing with the compression release feature in the engine and when set to specs enable the engine to start much easier. You remove the 4 screws in the valve cover and then with a metal feeler gauge check the gap between the rocker arms and the valve's ends.This being done after you remove the spark plug, turn the engine by hand until it comes up on the compression stroke and then 1/4" down into the power stroke, you hold it there and adjust the valve lash. I have the same machine and a new battery spins the engine quite well. Try the valve adjustment.
For you engage/disengage problem, check the action of the engagement lever behind the "dashboard" area and under the mower. The linkage to the lever needs to be checked and possibly lubicated if no foreign matter is jamming it's movement.
May 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard Machines RL 638, '07 model, will not start
Sounds like the blades may be engaged. The cable may not have disengaged completely the last time. When the engine is trying to turn over, the belt is engaged trying to turn the blades which could be why the deck is jerking. It will not start if the blades are engaged because of the safety switches.
Apr 30, 2010 | Yard Machines 155 Torque Briggs Stratton...
Craftsman riding mower lt 1000 deck jumps out
First I'd try lubricating the relevant moving parts. Spray with WD-40 everywher that makes sense.
If that doesn't help it work better, please, get bck to me.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
