Question about Thorens TD190-1 Turntable
Thorens TD190-2 puts down the pickup outside the record.
    Champion:
  • Thorens Expert
  • 271 Answers
Adjust at base of tonearm. Cheers john, Stylus City.
Posted on Jan 27, 2014
2 Suggested Answers
STYLUSCITY
  • 271 Answers
SOURCE: I have a turntable Thorens TD190 and i can't figure out what THE function is of the 17/30 switch? Can you help me?
It is a selector for record size. Ie. 30cm -12" records and 17cm-7" records. Cheers john. Styluscity.com
Posted on Nov 27, 2011
Which ports do I use to connect a Thorens TD166 turntable to a VSX D511 reciever, and does it require a pre - amp
Turntable plugs into an RIAA pre amp, (if not fitted within the turntable) then to a line level input on your amplifier.
Mar 27, 2017 | Thorens Audio Players & Recorders
How to fix my thorens TD 158 turntable that doesn't start automatically?
If the device opertated after you moved something then the chances are there is a switch attatched to the device you moved. This might have either got bent out of place or broken completly. Generally removing the bottom cover will reveal the inner workings. Where you can look around for the switch etc.
Sep 12, 2014 | Thorens TD158 Turntable
Thorens volume issue
You probably need to get a magnetic cartridge preamp to make it work. This will connect between the two.
Feb 06, 2014 | Audio Players & Recorders
Thorens TD190 speed problem
Depends if it is a belt drive or direct drive turntable. Most problems like this on a belt are caused by the belt itself, which will be found by lifting the platter matt up. If you need to replace the belt make a note of how it fits before removing it. You can find the belt by searching first for the make/model number and the word "belt". If that doesn't find it, measure in MM the diameter of the belt. You might also need to measure the thickness. Put that into Google with the words "turntable belt". You don't have to spot on with the measurements. Just get the nearest to yours.
If it's a Direct Drive, then that will be an electrical fault, so it might need the attention of a trained engineer.
Mar 30, 2013 | Thorens TD-190 Turntable
Nov 26, 2011 | Thorens TD-190 Turntable
Arm will not travel all the way across record before it lifts
Tonearm wiring is tangled under tonearm. Cheers john, Stylus City.
Sep 22, 2011 | Thorens TD295-MKIVB Turntable
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
Easrly stop
You will have to disengage the mechanical switch off lift. Pretty nice for an automatic turntable.
Keep me posted.
Oct 21, 2007 | Thorens TD-190 Turntable
Thorens TD190-1 Turntable Logo
80 people viewed this question
Top Thorens Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
