Question about Dewalt Saws
Looking for manual for de-walt cross cut saw r1450 type b 494235
2 Suggested Answers
  • 122 Answers
SOURCE: De Walt Power Shop DW125. Cutting problem.
Sounds like a dull blade or not enough teeth on the blade. Go with atleast 40 tooth.
Posted on Feb 02, 2010
I have a DE Walt DW307M recip saw. The blade broke off and I can't get the last piece out.
loosen the setscrew that holds the blades in.... then tap it gently with a nailset - - - it should loosen up after a few taps.
Mar 24, 2018 | Blade Saws
Where to find a manual for a De Walt Radial arm saw 720?
Try Googling (DeWalt)(720)(manual) without parens.
Aug 15, 2017 | Saws
De Walt radial arm saw old model 7740. Am trying to restore it to working condition Very difficult to change the height adjustment due to binding when trying to turn the handle on the top.
The manual for the saw is included below, To free the height it may be best to remove the saw carriage from the arm to reduce the weight.
Use WD40 or equivalent to cut the rust and a suitable grease to maintain the freedom. There is a worm screw that is below the cylinder that may need lubricating. The manual shows the assembly. I routinely apply 90 weight gear oil around the large tube where it goes into the housing,
http://vintagemachinery.org/pubs/252/1213.pdf
26351737-byjyd4kzhh1rgh2pqslbdjkq-3-0.jpeg Hope this helps?
http://vintagemachinery.org/pubs/detail.aspx?id=1213
Nov 12, 2016 | Delta Radial Arm Saw
De walt dc385
should come with a chuck key, or a key to lossen the blade. all of them lock in this manner regardless of manufacture. Check website of manufacture for this, or your mannal
good luck
Apr 30, 2013 | Saws
Drill Is Dead Fuse O.K.
Check the brushes for wear.
Most likely the cord has a broken wire , usually happens close to the handle of the drill.
To test, split the case ( puzzle screwdriver bits are avaliable from hobby shops ) and run a test light on the cord from the plug to the switch.
If the cord is ok , test the switch , they are quite flimsy on De Walt tools so be careful.
If the cord is faulty cut the damaged section out and shorten it.
If the switch, replace it . Check price, they are very hard to get here in New Zealand and very expensive.
If the Brushes, these should be avaliable from your De Walt retailer.
While you have your drill apart, check the bearings, De Walt uses common sizes,easily avaliable from a bearing shop and prone to seizing up and burning out the armature.
Mar 17, 2010 | Dewalt DW505 Electric hammer drills
Feb 02, 2010 | Dewalt Saws
Need Manual / Info For Old Delta Chop Saw / Cold Saw
The machine should have a data plate somewhere. This may give blade RPM or motor rpm, then its out witrh the calculator to work out the blade speed. The crucial number however is not the rpm but the peripheral speed in feet or meters per minute.
Used to work with a power tool manufacturer, a standard woodcutting chop saw will safely cut alloy. Two things, watch the blade type, and watch out for metal swarf entering the motor and switchgear !.
Feb 26, 2009 | Delta Saws
Operating manual
Hi hope this helps you!!
The link bellow will take you to de walt sight on there you will see your saw, on the right of the screen you will see "documents" There you can click on what you are looking for its a good sight for the future so save it!!
Hope that helps. Sean.
https://service.toolcommerce.com/Products/ProductDetail.aspx?ProductID=2906
Nov 09, 2007 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
71 people viewed this question
Top Dewalt Saws Experts
Craig Butler
Craig Butler
JOHN LAPIER
Tim Venetis
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
