Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
My salt water system keeps saying low salt but it has more than it is supposed to.
  • 297 Answers
Whats more than it is supposed to?
The manual is only a starting point
It is up to you to tweak it
The system on occasion can read low when it is high and vise versa
the system only really knows that something is wrong
Start by using a salt test strip that read in #'s not color like the six way that probably came with the unit
you need to get it to as close to 3000ppm as possible
any lower than 2700 and you will not produce enough chlorine and could trigger alarms any higher than 3500 and you could trigger alarms, go cloudy, and start corrosion on an aluminum ladder
If you are over 3500ppm right now ( since you say you have more salt than needed ) drain 20% of pool water a re fill with fresh circulate ( filter only ) for six hours check salt and repeat if needed until you get to the 3000ppm area
once close to the 3000 clean your electro cell as discribed in the manual and try again
you should be good to go
Posted on Aug 05, 2010
My salt water pump keeps saying low salt. I have had the water checked and there is plenty of salt. I have cleaned the cell and it still says low salt. The pump is on;y 1 year old. I dont know what else to...
I suggest you clean the cell according to manual and try it then. If it keeps producing chlorine then keep swimming. If the pump is flowing water fully (if not clean baskets and filter) and it can't keep the chlorine above 2 ppm and you have 30 to 50 ppm stabilizer in the water then there is a major problem in the chlorinator. I don't trust the salt indicator on some chlorinators but that is less important than if it chlorinates. You can but salt test strips. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says salt level low.....it seems salty enough as I can feel and taste it. Is there chemicals I am supposed to be adding or does this system keep it clean all alone just by adding...
While your problems are likely greater than just the salt content in the water I can tell you that if you feel, or more importantly can taste the salt in the water your salt level is WAY TO HIGH, not low. Have the salt level confirmed with an independent test either at a pool store or using a salt tester.
John
Jul 21, 2011 | Intex Automatic Salt Water System for ...
I have a 13X42 inch Metal Frame Pool and we have added over 55 lbs of salt to our pool and its still green and saying low salt.... what should we do and how much salt does out pool actually need??
You need to get water tested then add the right amount of shock + others and check in a few days to see where the water is at. The salt system only keeps pool right when in balance.
May 29, 2011 | Intex Automatic Salt Water System for ...
It keeps saying low salt i have an 18ft x 4ft deep circular pool and my salt water system wont clorinate
hello
there is too much for me to type please look up my name and posts about this issue
also look at my posts for low flow and green water
I promise you will learn very much about pool maitainence
Aug 08, 2010 | Intex Automatic Salt Water System for ...
Hi i have a 18 x 48 above ground intex frame pool with a salt water pump /chlorinator system. i have put the required amount of salt in 75 kg and it has fully desolved. the alarm keep coming up on the pump...
the amount of salt that they reccomend in the book is just a starting point
You need to get a salt test kit that reads in #'s not colors
Get your pool to as close to 3000ppm as possible
lower than 2800ppm and you will not produce enough chlorine
any higher than 3500ppm and you can trigger high salt alarm, have bad tasting water, or even get cloudy water
Like you have done, when adding salt , filter only for 6 hours or so to fully disolve
Jul 18, 2010 | Intex Automatic Salt Water System for ...
My Salt water pump keeps saying it is low on salt. I have added plenty of salt.
What is plenty of salt? There is a specific amount that you need Can't guess at it.
You must be above 2800ppm and no higher than 3800ppm
3000ppm is the best
You will need test strips for salt that reads in numbers not color
High salt can also trigger a LOW salt alarm
Don't ask me, it just happens
Just remeber 3000ppm
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
Keeps saying low salt level
I would say the rain is diluting the system at this point, or the system sensor has gone out. But if you had heavy rains I would be looking at that idea first.
thanks for using Fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 23, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
221 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
