Question about Sport & Outdoor - Others
John deere 310e backhoe. The machine has intermitten power. It runs fine at times, then loses all power and rpms drop to almost stahling the machine. We have changed the fuel filter and drained and cleaned the fuel tank. Problems seems tro occur after machine has run for approx. 20 mins.
  • tmc5280276 Aug 06, 2010
    john deere 310e. Machine has intermitten power. While using machine it will run fine then lose all rpms and almost stahl. We have changed fuel filter and cleaned fuel tank machine has 3660 hours on it.
  • 2,272 Answers
Remove the injectors and check. it's a motor issue running out of power. If the timing advance was not working properly, the tractor would break up a bit and skip at high RPM.Check the injectors and timing.also check the pressure of fuel. The problem lies there.Keep updated.Thanks.
Posted on Aug 06, 2010
  • 11,800 Answers
There's a bad contact in the wiring - when it heats up it interrupts. Start by checking the contacts on the dash then check the wiring to the kill valve on the pump.
Posted on Aug 05, 2010
What year is the following john deere backhoe 310G :t0310gx911769
You just go to the link I attached I'm sure you will get the solution of your problem.
Apr 25, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
HOW DO I BLEED THE INJECTORS ON A JOHN DEERE BACKHOE.I BELIEVE IT'S A MODEL 310
I have the 410 model,ran it out of fuel plenty of times in the past but never had to bleed the lines due to the electronic injector pump. If it just stalled then you probably dont have an air pocket problem. Most mechanics dont recomend using starting fluid on these engines,but if you are careful and dont try to keep the engine running on it you will be fine.If it starts and quits try changing the filter,or cleaning the tank filter.
Sep 16, 2014 | Garden
I have a 310SG john Deere backhoe and it loses power in 3rd and 4th gear on a hill I need help please.
I'm having the same problem with my jd 310. Did you ever end up finding a solution?
Dec 19, 2012 | Cars & Trucks
Won't start John Deere 310D Rubber tire backhoe
If you can test the alternator after it has run for 2 hours that would be helpful,if it is quiting after it gets hot then it likely need the stator replaced in the alternator.If this is not the case,then you need to either replace the park lock solenod valve or the instrument cluster is overheating a transistor and failing,this will cause the safety interlock circut to engage.Also the operator pressence switch may need to be relocated if the operator is less then 150lbs.Let me know how you make out,thanks.
Apr 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
