Question about Water Heaters
We change the burner for the water heater, it stay li ari=ound 35 minutes, heat the water and after is turning on completely, even the small flame don't stay lit. What we need to do?
  • 3,640 Answers
You mean it is only staying on for 35 minutes, if this is the case, then readjust or replace thermal coupling, if bad it will not sense the flame or pilot light. it has to be in pilot light flame as to work properly. ( this is for a gas hot water heater). if bad it will shut gas off to heater.
Posted on Aug 05, 2010
Does the center flame under burner on model#850NKRT continuously burn?
if unit calling for heat the small flame is the pilot if large flame stays on bad temp sensor or board
Oct 17, 2016 | Reliance Water Heaters
The water heating burner does not go out there is a small like pilot light burning after the temp shuts off on the main burner.
Bad gas control valve? Wrong gas control valve for water heater?
This is a dangerous condition... immediate repair needed ... fire and explosion hazard.
Call plumber... or replace heater
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 07, 2014 | Reliance 6 30 DORS 606 Series 30 Gallon...
Rheem Rudd G91-200 will not start. After waiting 10 minutes, it does fire up for about 2 minutes, then it locks out. Bad gas valve?
ive never seen one of these water heaters but most gas apps have a thermo-couple which the ignition flame needs to heat the top of.if the ignition flame is missing the top of this the main gas valve will shut off.it may just be a bit of dirt in the flame director.which aims gas at the couple and main gas burner.hope ive helped.good luck
Mar 16, 2013 | Rheem Tank Water Heater G91-200, 91 Gallon
GCV 40 100 Burner and pilot shuts off when heating up
Get more fresh air to the unit.
Clean the air intake/ flame trap/ flame arrestor located on bottom of tank.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment with type of gas control valve, for possible troubleshoot.
Copy following link to read service manual by type of gas control valve:
Aug 17, 2012 | A.O. Smith GCV-40 Promax Residential Water...
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
AO Smith Burner Issues
This system uses an electrical test to make sure that the burner is lit. The flame sensor will either be broken or will be covered in deposits (clean with an emery cloth).
The flame sensor is usually a small metal rod that would be in the direct line of fire of the burner with 1 wire attached.
CAUTION:
The ignitors can be very fragile and are expensive. They are very brittle, do not touch it.
Jun 07, 2010 | Water Heaters
Rheem gas water heater it won't stay lit...will lite up and go off after 20 seconds or so. If I leave it sit for 20 minutes the exhaust fans blows but no flame and I have to turn off gas and refire up to...
For the main gas valve to come on several conditions need to be met.
The system must detect a pilot light prior to turning on the main gas valve for systems with a standing pilot light (not sure what your system has) and on systems with auto igniters (spark or ceramic heat glo) the control board must detect a flame present at the main burner a few seconds after the main gas valve turns on.
The other condition that must be met on systems with power exhaust systems is a vacuum/pressure diaghram switch must be made and stay made telling control circuits that vacuum/pressure is present = power exhaust fan is on and working.
From your description it sounds as if you may have a dirty/failing flame detector (thermocouple). Remove it and give it a good scrubbing with a scotch brite pad etc. cleaning off any carbon or corrosion/gunk re-install and try it out, or simply spend $15.00 or so and install a new one to be sure. The thermocouple is the metal thin tube that protrudes into the pilot and/or main burner flame and is connected to the main gas valve by a thin capilliary tube.
To check the vacuum swich on the blower a multi meter across the switch terminals looking for a steady "state change" as the blower runs/stops will work.
Oct 24, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Whirlpool Water Heater flame goes out shortly after being lit.
This problem sounds as if gas pressure to the burner is to low, check mnfr's plate on heater for the correct burner manifold pressure, you will need a manometer or a guage that measures inches of water column, set the pressure correctly and the burner should stay lit.
Jul 03, 2009 | Water Heaters
Water Heaters Logo
87 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
