Question about Home
How does the sink fix to the wall? - Home
  • 454 Answers
A free hanging sink slides onto some brackets affixed to the wall. To remove the sink, simply disconnect the plumbing and lift the sink straight up.
Posted on Aug 05, 2010
How do I hang an object using drywall anchors?
hi there.
Sink A Self-Drilling (Threaded) Anchor
  1. Mark your hanging point with a pencil.
  2. Tap the pointed tip of the anchor into the wall with a hammer.
  3. Once the tip is in the drywall, with a screwdriver, screw the anchor in until it's flush to the wall.
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/
How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls
How do hang an object using drywall anchors Google Search
Nov 28, 2017 | Drywall
I am replacing my sink, medicine cabinet and adding a small cabinet below the sink. I need to know how to remove the old and install the new.
The task you are embarking on is a great DYI project. But, be forewarned, it can get tricky. First, make sure the new sink will fit in the space of the old sink. If not do you have enough space for the new sink to fit securely against the wall? Next, remove the cabinet. There should be about four screws. You may also have to use a razor to cut calking from around the outside of the cabinet. Sometimes it's used to fill-in gaps between the tile and cabinet. Remove the cabinet. If the cabinet is setting in the wall, make sure you check and see where the support beams are located. If you are not putting in another wall cabinet, then you will have to know what kind of wall you have. Sheet rock, no problem. Plaster requires a bit more work. Measure the hole, and then you will need chicken wire, lime, plaster, paint, and matching tile. Fasten the wire to beams in the wall. The wire will hold the plaster in place. Let dry, sand smooth then paint. If you have sheet rock walls measure the hole cut the sheet rock to fit. Fasten it to the beams, use plaster or Spackle to cover the holes from the screws. You will need sheet rock tape to hide the space between the existing wall and the sheet rock patch. Smooth on cover the tape with Spackle, smooth by sanding.
To remove the sink: first, turn off the main water supply. Get a pipe wrench and remove any connections. If you're not familiar with plumbing you may want to get a plumber to attach the connections.
Putting a cabinet under the sink is the easy part. Make sure you have the right size cabinet. Get a leveler; make sure the sink and cabinet are level. Depending on your walls, you can just screw the cabinet to the wall. If they are plaster walls you will need wall anchors. That should do it. Enjoy
Feb 23, 2013 | Plumbing
Sink falling off wall
Well first step would be to remove sink from wall.then determine if there is backing in wall (something study behind wall to anchor bracket to) Most of the time when its falling off the wall its due to improper backing or non at all, bracket mount screw rusting away.I seen sheetrock screws holding them on. (that would last long) I suggest 3/8x 2" lag screws.
Feb 03, 2012 | American Standard 0194 - Roxalyn...
Is plasterboard (with battens behind) strong enough to install a Roca Kalahari wall-hung sink against or do I have to reinforce it using tiles or a bracket?
Ok. Big answer. Where the sink is going to be mounted there needs to be inside the wall structural support mounted between the wall studs. This could be a 2X6 or 2X8 nailed from one wall stud to the next at the height the sink will be mounted. Then once you have repaired the sheet rock you can measure the distance the mounting holes in the back of your sink are and drill these holes smaller than the mounting bolts/screws for your sink. Screw the screw portion into the wall using the nuts on the bolt side and a wrench. Remove the nuts and the slide sink into place where the bolts/screws fit into the mounting holes in the sink back. Install washers and nuts and tighten to wall.
Sep 01, 2010 | Roca Pacific Semi-Recessed Basin - Black
Our disposal will not turn on and we think it is a switch. How do we fix an insinkerator switch?
Underneath the motor is a red reset button. Push up on it to reset. If it clicks, it is the problem. Unit sjould work with wall switch, if not make sure unit is plugged in under sink andno GFCI outlets are tripped.
May 23, 2010 | Emerson InSinkErator STC-BLK Sink Top...
I have a sink in bathroom I have removed cabinet and there is nothing to hold up sink can that be anchored it is round sink with 1/2 inch lip caulked to bottom of counter i also want to remove do i have to...
I DON'T RECOMMEND TRYING BOLT THIS TO THE WALL UNLESS YOU HAVE THE WALL BRACKET THAT COMES WITH THE SINK,NOT ALL SINK ARE DESIGNED TO BE WALL HUNG.
Apr 20, 2010 | Home
I have bolted a pedestal sink to the wall. The pedestal is a separate piece, and is loose under the sink. Evidently the sink is bolted slightly too high, though I had the sink resting on the pedestal...
Place spacers between sink and pedestal.You may need to replace current screws or bolts with slightly longer ones to compensate for the spacer thickness. Spacers could be almost any materiel but plastic or rubber would be best against water damage.
Jul 08, 2009 | Home
My gargabe disposol won't turn off.
sounds like the wall switch needs to be replaced.
Apr 05, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
