Question about Kitchen Ranges
What is F2 code mean on model #JKP56AOA2AA serial no# LV2816910
  • 1 more comment
  • CINDY445 Apr 26, 2008
    I was cleaning the ovens when the F2 code came up, turned the breaker off let it set for 2 hours. The doors unlocked the top oven works the bottom oven you can set the controls but the oven will not heat. What does the F2 code mean?
    GE profile Model number JKP56AOA2AA
    Serial number LV2816910
    Where is the sensor? Is it the probe in the oven or is it in the control panel?
    Genius:
  • 1,073 Answers
F2 is sensor problem it is seeing a tempratue above the limits of regurlar baking or self clean cycle replace the sensor
Posted on Apr 26, 2008
    Genius:
  • 3,587 Answers
Can you provide the make and model number, please?
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
I have a GE oven, model #JTP15W0W2W, serial #SS605844R that the bottom heating element does not work and the screen flashes F2. I contacted GE and they recommended I change out the bottom heating element,...
Ge should know their own codes. F2 for GE means oven control senses overheat over 600 degrees
Go here for code desciption . You should be able to fix youself
http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes
best of luck
matt
Aug 15, 2011 | GE Ovens
F2 signal on Jenn-Air model su146 range
Hi there
i have found the code for and hope this helps you.let me know how it goes.
F2 Oven too hot Replace relay board (if present) or oven temperature sensorThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | Kitchen Ranges
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
Error code f2
This usually means the oven detected an over-temperature condition (although F2 meaning varies by model). This can be caused by a faulty temperature sensor or a failed control board. Many of the control boards for the older models have been discontinued. We repair these at www.fixyourboard.com.
Oct 05, 2009 | GE Ovens
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
F2 error code on GE built in Oven Model JKP13GOP
Your error code means this. F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
Good Lock and Please Rate FixYa!
Dec 27, 2008 | GE JBP90 Electric Kitchen Range
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
