Question about Kenneth Cole KC1333 Watch for Men
I need a tiny screw to faten one side of the wrist band to the watch. Where do i get such a screw?
  • 2,334 Answers
Visit any nearest watch repair shop. They will fix it.
Posted on Aug 05, 2010
Replace batteries on spf-40 model 2273
Looking at pictures of the watch , you will need to remove one side of the strap by undoing the screws on the side of the strap.
once you have removed one side of the strap unscrew the four screws on the case back of the watch.
then you will be able to lift the case back of the watch , it has a rubber seal on it which you need to carefull not to break.
Good luck and be carefull.
Sep 19, 2017 | The Watches
Adjust the bracelet
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.)
A jeweller could do it, needs a special tool to tap them out and put them back
Nov 03, 2013 | Rolex Oyster Perpetual Submariner Date...
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    How do you remove a link in the band
    Unscrew 2 screws from the side of the band.This will release one link. Screw the rest back together.
    Aug 04, 2010 | Rolex Daytona 116520 Wrist Watch
    Have a watch band with slot and arrow on one side need to shorten
    The arrows indicate the direction that the pins punch out. Its possible that it has tiny little sleeves that put pressure on the band which hold the pin in. Take it to a reputable watch repair shop...they can assist you with your adjustment! :-)
    Jan 17, 2010 | Kenneth Cole KC3289 Wrist Watch
    I have an new band for the G-shock 500A but can't figure how to get the screws out of the old band to replace it. The screws turn both ways and don't seem to move. Is there some trick or special tool I...
    Yes, You need two screwdrivers. One for each side. One screw on one side is long and goes all the way through the watchband and threads into the screw oon the other side which is smaller. Once you have backed the longer screw all the way out, you should be able to give the watch band a few light taps and the long screw should fall out. The screw on the aother side may require a bit more tapping or coaxing with the screwdriver to remove it. Once both screws are out, you can remove the watchband.
    Sep 22, 2009 | Casio G-Shock GW500A-1V Wrist Watch
    I need to change my watch band
    Where the band meets the watch - push the band a bit to expose the pins that hold it on.. The pins are spring loaded and will compress with the push from a tiny flat screw driver..
    You can get replacement bands at most retal stores..
    OR - take the watch to WalMart jewlrey dept and find a band that fits and they will help you chang it..
    Good luck ;o)
    Sep 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Watch band resizing
    This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out.
    * I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
    Jun 27, 2009 | Lucien Piccard 26024 Wrist Watch
    Beverly HIlls Polo watch needs band adjustment
    All you prepare a piece of jewelry screw.There will be very tiny screw in the side of the band you better screw it carefully and when the screw is out detach it,and size it that's you like size comes out.That all if want to resize desame what did in the other side. Always do it slowly so there no scratch or visual impaired damaged.
    Jun 16, 2008 | Beverly Hills Polo Club 22-710TTS
    Shortening the Length of a Metal Wrist Band
    I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
    Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
    Kenneth Cole KC1333 Watch for Men Logo
    Top Kenneth Cole Watches Experts
    Ansel Alberto
    Ansel Alberto
    Robby Otts
    Robby Otts
    Level 1 Expert
    Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
