Question about Paragon JW-30-00 Percent Cycle Timer
Can I buy a replacement motor for this timer and where
  • 52 Answers
Intermatic troubleshooting
You need new 120V WG1570 clock motor
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
Order extra trippers too... motors and trippers are replaceable so timer can last 25+ years
http://waterheatertimer.org/Buy-T100-series-timers.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 27, 2014 | Intermatic Hardware & Accessories
Model 4003 00 timer
There are no replacement motors for paragon series.
Replace with 120 volt Intermatic T103 timer or T173 skip-a-day timer
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Gene
Water Heater Timers Save Money
Dec 27, 2013 | Paragon GENERIC REPLACMENT MECHANISM 110V...
Pool pump clock
T104M used WG1573 clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
The timer mechanism has metal gears, while the clock motor has plastic gears. If the metal gears get dirty and bind, it will strip the plastic gears.
Turn off power, pull timer out of box, Clean out timer with compressed air, and spray WD40, add a bit of white grease to lever where trippers make contact, then replace clock motor ... and buy another set of trippers to have on-hand since they are designed to wear down so timer will last longer.
If timer body is broken so dial does not rotate, then buy new T104 and snap new mechanism into old box. Buying whole T104 with enclosure is cheaper than buying T104M mechanism only.
May 15, 2013 | Pool & Spa
15600 wiring problems
You probably have wrong voltage, or wrong wiring.
For example 15600 is 120Volt timer mechanism made by Tork and sold by GE.
This timer will not work with 240volts.
Other cause: Line and Load wires might be reversed.
Check circuit breaker.
Use non-contact voltage tester to see if power is live at timer.
Check wires at each terminal and make sure wire insulation is not under the screw plate.
Copy following link for wiring diagram:
http://waterheatertimer.org/GE-timers-and-manuals.html#15600
FYI, it is usually cheaper to buy T101 timer than GE15600, and then parts are more widely available and cheaper.
For example WG1570 clock motor for Intermatic T101 is $16.
Tork replacement motor is twice as much.
If you have 240Volt power, instead of 120Volt required by 15600, then you can buy Tork 201 clock motor and replace the 101 motor.
GE 15600 uses Tork p47 trippers.
http://www.globalelectricalsupply.com/Tork-Motors-p/motors.htm
Jun 17, 2012 | Hardware & Accessories
Can i buy parts to replace the internal parts? my timer works but will not click the tab light something is stripped.
You can buy trippers for Intermatic ML series, but there are no replacement clock motors or transformers.
I don't know if tripper is the problem or maybe clock motor is getting weak, and will stop working.
If timer is not working, but manual override works, then buy cheap plug-in timer and plug power pack into cheap timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Malibu ML300RTW - Low Voltage Power Pack...
I have intermatic timer T30003R. How do I change the timer motor
My understanding is this timer uses typical T100 series 120Volt clock motor.
The motor has identifying numbers printed on it.
T100 series 120V clock motor is available at Grainger:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Selection of Intermatic clock motors are available on-line:
http://www.electricsupplyonline.com/prod/intermatic-motors.php
To replace motor:
Timer mechanism snaps out of box using a thumb-spring located at top of mechanism.
Clock is located on back of mechanism, and is held by 2 star-screws.
You can buy star screwdriver bit at auto parts store or hardware.
Clock motor has two white wires that are connected to terminals on front of timer.
Be sure to tighten terminals screws very tight after replacing clock motor.
Jan 10, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
My automatic timer is not working.
You posted under Intermatic raintight timer.
Add a comment with your model and brand and I have extensive files on timers.
The best diagnostic is the manual override.
1) Click manual override and see if Load (lights, fan, motor) come on.
If manual override clicks on-and-off crisp and clean, but the lights do not come on, check your electric power.
If the manual override does not click crisp and clean, then the timer may be rusty, or timer may need to be replaced. Buy replacement timer and swap out timer mechanisms without changing the box.
If the manual override works fine, and Load turns on-and-off with manual override, then the clock or trippers are next suspect.
2) Check if the dial is turning as time passes.
If the dial is not turning, then the clock motor is bad and you can buy a new clock motor.
If dial is turning, and manual override turns Load on-and-off, then the tripper pins might be worn out, and you can buy new trippers.
3) To buy replacement parts: Timer door has model number of timer. Timer clock located on back of timer mechanism has identifying numbers. You can snap out the timer mechanism using metal spring locate top inside box.
Grainger sells trippers and motors:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Aplus sells motors:
http://www.aplussupply.com/intermatic/timermotors.htm
Intermatic sells motors:
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Nov 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
The timer clicked OFF but poot pump kept running. Had to trip breaker to stop pool pump.
Your Intermatic timer has a manual override.
The override is a good diagnostic.
Click the manual override and see if pump turns on and off.
Next, watch if the clock is rotating.
If the clock is rotating, the OFF tripper may be worn out and you need a new tripper
If the clock wheel is not rotating, you need a new clock motor.
If you have T104, your clock motor is 240Volts
If you have T101 or T103, your clock motor is 125Volts
Buy trippers and clock motors at Grainger
Clock motor replacement takes a small star-screwdriver bit
If your manual override is not working, then the gears might be rusty and need to be cleaned or your timer needs to be replaced.
You can buy same model number timer and then swap the insides without changing boxes.
Add a comment if you need more help.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Nov 02, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Timer does not activate setting wheel. Stays on or off all the time.
1) If wheel is not turning, then replace motor
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
There are numbers printed on clock motor. Also look inside door to see model number of timer. If you have a T101 or T103, T104 the T100 motor will work.
2) If manual override is not working, then replace whole timer.
3) You can buy same timer, and then swap insides
without replacing box. For example if you have T101R, the R stands for rain-tight box. Buy T101 and swap insides. Keep in mind T103 and T104 and T101 are not interchangeable due to wiring differences.
http:waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Sep 15, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Timer stopped working Manual mode turns things
Usually the timer motor is bad when that happens. You can purchase a new timer motor here (or at a similar website):
http://www.aplussupply.com/intermatic/timer.htm
If you don't want to mess with replacing the timer motor can can buy another time clock and as long as your existing enclosure is still in good shape, just swap out the guts.
Apr 07, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Paragon JW-30-00 Percent Cycle Timer Logo
75 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
