Question about Dishwashers
Diplomat 8352 water not draining caused kitchen floor to flood
  • 487 Answers
Your pump is obstructed. take out pump and clean it out. Your filter might be plugged too. As soon as it floods it also can be a leaking hose from the pump.
just open the machine and you will see the pump straight away.
Not difficult
Posted on Apr 26, 2008
Kenmore washing machine 2 year old is now flooding my floor every 20 loads happiend 4 times. Please help.
Is the water flooding coming from the top of the washing machine?
Check the drain pipe in the back to see that it's not loose. Also, look inside the drain pipe and make sure there is no algae. Algae might cause low flow through the drain pipe and it will overflow.
Hope this helps.
Feb 07, 2014 | Washing Machines
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Too much sink water causes flooding from dishwasher.
If you let it sit with vinegar and it worked after for a while that tells me it may be plugged up with grease. Might be worth while trying to clean it out with Drain O a drain cleaner. Make sure its washed clean after. Grease and dirt builds up after a while in all machines. If vinegar works might be worth cleaning more often.
Mar 14, 2017 | Maytag PDB4600 Built-in Dishwasher
Washer does not spin out and drain water. what could be causing this?
Possible pump failure or maybe just drain filter blockage , refer to user manual , clean filter , replace and re-try N.B. If machine is still full of clothes and/or water you will need to remove this first or you risk flooding your kitchen floor.
Nov 03, 2009 | Washing Machines
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Dishwasher fills with water when running faucet
The drain hose from the dishwasher should exit the dishwasher, then head up to the nderside of the counter top, before heading back down to connect to the disposal drain connection.
If the drain hose doesn't do this, the dishwasher is improperly installed, and clean dishes risk being contaminated, which can cause people to become ill.
Jan 25, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher filling
check to see if you have anything plugged
Mar 26, 2008 | Dishwashers
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
180 people viewed this question
Top Dishwashers Experts
