My laptop is not switching on when you press the power button its just making a sound but does not switch on and quickly switches off
    Sergeant:
    Champion:
  • 277 Answers
If this is an Acer, chances are you lost your CPU because of poor air circulation.or you video.
For the past 3 or 4 years Acer and other machines are poorly designin their machines,order for you to buy another one.
That is why you buy Toshiba, Sony,Hp ,Lg.Compaq, Dell
Emachines,Acer, Gateway all belong to a company that DON'T care about their customer and try to get more money from you
Posted on Aug 05, 2010
Systemax SYX-SBT-X58 desktop.Is there a front power switch part for tower or another alternative available?
I can't see how holding the button a little longer would make any difference, the button press sends a quick little signal to start the BIOS operating system built into your motherboard. Maybe you just need a new switch as it could be shorting somewhere when you press it a certain way. You can remove the wires from the back of the switch and touch them together to see if the pc starts. If that is too complicated then i would suggest taking it to a store before any real damage is done.
Dec 15, 2017 | Systemax Computers & Internet
How do I repair the power off and on button on my laptop?
There is no quick fix. If you are competent, strip the laptop down and check the switch actuator as I have never had a power switch that didn't even work intermittantly. Look for any signs of damage.
Jul 08, 2014 | Fujitsu Computers & Internet
Alienware power button
it is possible the power switch behind the button has slid out of position. The power button on the machine is usually more of a "pretty face" to press the switch behind it. I would take off the front cover of the PC (be careful not to break any tabs etc, they are usually plastic and easily breakable) and then try pressing just the little switch directly behind the power button on the front panel....if this works every time, you may need to push it forward from the rear a little bit so that the power button on the case's faceplate is making solid contact with the switch.
Feb 25, 2013 | Alienware PC Systems Alienware m15x Gaming...
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
When switch on laptop,high sound coming
Hi
If your laptop is making a high pitch of noise (long beep) and the laptop is not having any problem booting to windows (operating system) there's a possibility that one of the button is pressed also known as sticky key
Switch off your laptop try to touch and press all the buttons and try to switch it on.
If you will encounter the same thing wait until the laptop boot to windows and open the notepad application and try to use all the buttons
If some of the buttons are not working or some buttons automatically press the problem will be on the keyboard
Is it okay if you will send more information regarding with the high sound coming from your laptop after switching it on because I would be happy to assist you and resolve your question with accurate answer . Thank you : )
Oct 22, 2011 | Samsung RV511A01 Notebook
Power button on my HP Pavillion dv6102od does not work. Can't force a reboot by holding it down for 5 seconds either. The power button became a bit intermittent, then failed completely. I have removed...
I don't know if this will help, but I had a very similar problem with a DV6700. Pressing on the power coverplate used to get the laptop to boot up. Upon investigation, it turned out to be the ribbon cable from the switch to the board. This is very badly routed and over time, pressure damaged the inner wires. Got a new one from ebay at the cost of £2.00 and I was back up and running in no time.
The DV series of laptops did start to fail and HP were aware of it but did nothing after the warranty was over, common failures were the wireless card port, the speakers and the gFX chip, usually caused by oerheating
Aug 16, 2011 | HP Pavilion dv6102od PC Notebook
I press the switch on button to activate laptop and it just switches back off
Please check whether the laptop power button may be in the pressed mode.. please release the key. If the key is not released after you pressed the power button, the laptop will power off.
Clean the power on button.
Hope this works..
Jul 11, 2011 | Fujitsu AMILO PC Laptops
It's dead! I switch it on and nothing happens at all. The power is fine as the power light comes on but no others & it makes a small sound as if trying to start but then nothing. It takes a good ten...
remove battery, plug the power, turn it on. your battery may have completely discharged that your laptop is having hard time charging it and powering the system at the same time,
Nov 06, 2009 | Acer Aspire One PC Notebook
How to program a 2009 Honnda Accord Key Remote
Want to programs the remote key of your Honda cars, then you must reprogram all of the key-less remotes of your Honda Accord once you are in the programming mode. You must complete each step quickly so to prevent the system from exiting the programming mode.
Note: Maximum Three remote transmitters can be programmed.
Make sure all the doors are UNLOCKED before starting this programming procedure.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNLOCK button on one of the remotes. (An unprogrammed remote can be used for this step.)
3. Turn ignition switch to ACCESSORY (I) or LOCK (O)
4. Turn ignition switch to ON (II)
5. Press the LOCK or UNLOCK button on one of the remotes.
6. Turn ignition switch to ACCESSORY (I) or LOCK (O)
7. Turn ignition switch to ON (II)
8. Press the LOCK or UNLOCK button on one of the remotes.
9. Turn ignition switch to ACCESSORY (I) or LOCK (O)
10. Turn ignition switch to ON (II)
11. Press the LOCK or UNLOCK button the same remote. Make sure the power door locks cycle to confirm you are in programming mode.
12.Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle after you push each remote button to confirm system has accepted the remote.
13.Turn the ignition switch to LOCK (O) to exit programming mode.
14. Test remote(s)
For more clarification, i have also shared the video to do this process, Have a look
Apr 09, 2009 | 2009 Honda Accord
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
