LG model 32LC7D-UB.AUSVLJM This tv will not work with the remote. I confirmed remote is good. I replaced the remote ir sensor and it still is not responding to remote. LG tells me its the main board and it'll cost 200 bucks to fix. Help.
  • Patrick McAlexander Aug 05, 2010
    They are firm on the 200 dollar replacement board. I would think there is a diode on the main board or something. Thanks for your help.
  • 3,866 Answers
Correct its the main control board that controls the IR sensor there 100 percent correct on the region effected, Now $200 bucks for them to fix ya up is a little out of the world I would just assume you purchased another TV at that point.
What you need to do is purchase the part not from them from www.partstore.com or Matts eletronics and put it in yourself you will save huge $$$.
So they are correct your control board needs to be replaced that is a confirm but the price is not correct, and I would never tell someone to accept that responce.
Let me know ehter way I am intrested hearing your feedback,
Thanks
Please do click reply to expert or close this case with the accept button, thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 05, 2010
LG 32" TV remote function fails to work intermittently. Works by using buttons on side. LG's remote for sound and DirecTV's remote for turning on station tuning. Batteries new in both remotes.
Try looking for the remote sensor. It should look a little like a camera lens or little red tinted window. If you cannot find it just give the entire front of the TV a good cleaning. Finger prints and dust build up can interfere with the signals. Do the same for your direct TV box.
Jun 02, 2015 | LG 32LC7D Television
How to replace the IR sensor in a 42LG50 tv
how do you know the remote is working properly if it won't work the TV
Jun 01, 2015 | LG Televison & Video
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
My remote no longer works with my tv. I think its the ir sensor but I don't know what it looks like to replace it. I have another tv of the same model for parts and need to know what the ir sensor...
You can confirm your remote's IR output by pointing to the phone camera and if the remote works it will be seen as a flash on the camera. Now after confirming the remote then the the IR detector on teh TV can be checked. It is always mounted on the FRONT panel and is a small DIODE mounted to face the IR panel ****. It is easily seen and can be checked using a multimeter . In the Ohmn's range in one direction a flash of light will increase the flow and continuity when the probes are held across the diode. If teh IR is good then it is a fault on the processor controller.
Jul 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My control remote doesn't work
Hi, first if remote doesn't work, try new batteries......
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
May 08, 2011 | LG 32LC7D Television
I have a 60 inch lg tv. The remote just stopped working Put in new batteries. Tv button lights up on remote but will not turn tv on.
Let me know model number of your 60 inch LG tv to find out possible cause of no remote operation.
I do not think that IR receiver is bad in your tv. Regarding dusty IR receiver lens, you can confirm it by sending remote signal by very close distance to tv.
There are few other possibilities of no remote operation problem instead of bad IR receiver.
Aug 25, 2010 | LG 42LC2D 42 in. LCD HDTV
My LG stopped receiving signal from my remote (I tried 2 different remotes and confirmed it was a problem with the TV). Is there any fix for this? Can I do it myself?
You can check to see if the remote IR receiver module is getting the 5vdc feeding it first, you will need a scope to look at the output signal from the IR board, or you spend $10 to try replacing the IR board. http://www.shopjimmy.com/catalogsearch/result/?q=LG+32LC7D+
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jul 21, 2010 | LG 32LC7D Television
My remote stopped working... I tried to reprogram my ATT universal remote then tried the remote that came with the tv. Neither is working.
The IR receiver in the TV may have gone out, but check the remote signal first.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
www.remotes.com
Jul 15, 2010 | LG 32LC7D Television
Remotes stopped working
Have you tried contacting LG. They may be able to help you out
Jul 19, 2009 | LG 32LC7D Television
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
