Question about Kenmore Coffee Makers & Espresso Machines
Kenmore Elite 14 cup coffeemaker model 100.91016 beeps and will not brew. No filter is in coffeemaker.
4 Suggested Answers
hbaby_girl
  • 13 Answers
SOURCE: Kenmore Elite coffeemaker water filter
http://www.kenmore.com/shc/s/p_10153_12605_00869768000P?filter=Price%7C%240-260%5E&vName=Appliances&cName=Small+Kitchen+Appliances&sName=Coffee%2C+Espresso+%26+Tea+Makers
Try here. Hope this helps.
Posted on Jan 08, 2008
txkjun
  • 409 Answers
SOURCE: coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Posted on Jan 12, 2009
SOURCE: My kenmore 12 - cup coffeemaker, model # 80666 is
In the manual that came with the coffee maker, the beeping is the freshness alert. When coffee is finished brewing it beeps 5 times. Every 15 minutes it beeps to let you know your coffee is 15 minutes less fresh! I just purchased this coffee maker and was looking on here how to dis-assemble the beeper. Whomever came up with the "freshness beeper" on a coffee pot needs a new job! Usually when I make coffee the whole house is asleep, now the beeping is waking everyone up! Very frustrated with this coffee pot!
Posted on Dec 28, 2009
Filter lid spins properly, brew lights are on; but it won't brew coffee.....please help
How to Repair a Cuisinart Coffee Maker - Java Jenius
www.javajenius.com > How-To
How can I flush it if it won't brew at all? ..... The filter basket is in the proper position for the coffee to enter the filter but the ... I have a regular cuisinart coffee maker for12 cups (no grinder). ... I have the Cuisinart automatic grind and brew, model DCC490SA. .... The pot brewed a good cup of coffee but as of now it is useless.
Jan 21, 2016 | Cuisinart DCC-790PC 12-cup Grind & Brew...
My kenmore 12 - cup coffeemaker, model # 80666 is beeping every few minutes. I hit the brew button but nothing happens
Nov 02, 2009 | Kenmore Coffee Makers & Espresso Machines
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
Coffeemaker will not brew a full pot
Jan 12, 2009 | GE 106591 Coffee Maker
Beeping only, and the coffeemaker won't brew at all
Check first that both filters (the water filter and the grounds filter) are in place correctly. Also check that the white tab in the grind cover moves freely when the lid is closed. (You can use a fork tine to test.) If that doesn't solve your beeping issue, contact http://www.cuisinart.com/support/us.html or 1-800-726-0190. I did and they are sending me a new unit at no charge.
Sep 30, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
If it's only 2 months old, I would suggest taking it back to Sears and getting it replaced under warranty.
Geno
Mar 10, 2008 | Kenmore KBC12 Coffee Maker
Kenmore Elite coffeemaker - excess steam
Fold a large piece of foil into quarters. Place foil over reservoir and firmly close lid. Open lid and massage edge of foil inside and out with finger to get a kind of cap. Remove foil and trim neatly around outer edge of lip. Fill reservoir with water, place cap on top and close lid. Make coffee.
Mar 02, 2008 | Coffee Makers & Espresso Machines
How do I use the self-cleaning option
According to the manual for IS series Mr. Coffee for programmable models:
1. Prepare one batch of Mr. Coffee coffeemaker cleaner. Pour the mixture into the water reservoir. Remove the water filtration disk from the machine.
4 cups or 20 oz. of undiluted, white household vinegar may be used as a substitute for the cleaner.
2. Place an empty paper filter or permanent filter into the filter basket and close.
3. Place the empty decanter back in the unit, centered on the warmer plate.
4. Press SELECT button until the red CLEAN indicator light is illuminated. For your convenience the cleaning cycle is automatic. The entire cycle will take 45-60 min to complete. During the cleaning your coffeemaker will:
  • Slow brew approx. 3 cups of cleaning solution.
  • Pause for 30 min (the CLEAN light will remain on to alert you that the process is active). At the end of the pause period your coffeemaker will beep.
  • After 30 mins your coffeemaker will brew the remainder of the cleaning solution.
  • When complete, the CLEAN light will turn off and your coffeemaker will automatically beep and shut off.
5.Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean fresh water.
7. Place the empty decanter back on the coffeemaker, centered on the warmer plate.
8. Remove and discard the filter used during the cleaning cycle and replace it with a fresh paper filter. If a permanent filter was used during cleaning, remove it and rinse it thoroughly before replacing it in the filter basket.
9.Begin brewing and allow the full brew cycle to complete.
Repeat steps 6-9 one more time.
Nov 23, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Oct 08, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
101 people viewed this question
Top Kenmore Coffee Makers & Espresso Machines Experts
Jude24
ray gallant
 steve
steve
Are you a Kenmore Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
