Question about Thermador SC302T Electric Double Oven
I have a Thermador electric double oven, model SCD302, approximately 11 years old. Neither oven will turn on the bake cycle. Only the convection fan will turn on on the convection cycle. Can you tell me which part/parts might be the problem. Thank you,
  • Thermador Master
  • 2,605 Answers
Welcome to FixYa.
You have not mentioned if the oven has displayed any error code so I will take that for what it is...there was none shown.
With that, I`d start by looking for an overtemp cut-out tripped. Did this problem start following a self clean cycle ?
Here`s what and where to look for for this,
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
**Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...
Ultimately it could be a faulty relay board or related to the timer, but I`d start with the hi-limit cut-out tripped first.
If you feel capable of repairing this yourself I can send you a complete service manual in a "pdf" attachment, however you`d need to provide an email address to where I could send it to you.
Other than that if you call in a pro just be sure they are an authorized B/S/H/ service provider ( B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens products ).
Let me know and I`ll watch for your reply and respond as soon as I can.
macmarkus :)
Posted on Aug 05, 2010
  • cesarap117 Feb 10, 2011
    macmarcus thank you for your help i have a thermador electric double oven c302 top oven wont bake or broil. after i reset overload as you suggested the convection works what next relay board must be expensive cesarap117@aol.com
  • koosh19618 May 06, 2011
    exact same problem can you send service manual to koosh19618@yahoo.com
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Set clock on an old thermador double convection oven
Turn the main knob counter clock wise until the display reads "clock", then turn the same knob clockwise to set the time. When done, push the select button.
Feb 25, 2012 | Thermador SMW272 Electric Double Oven
I'M LOOKING PART OF THIS MODEL Thermador SCD302TP
Hello, welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door seal for your SCD302 series Thermador double wall oven. They should have anything you need.
http://www.repairclinic.com/Model-SCD302TP-ID-642642-Parts
Thank you for choosing FixYa and good luck. Please take a moment before leaving to rate the assistance provided here and your experience at FixYa.
Regards,
Macmarkus :)
Sep 19, 2011 | Thermador SC302T Electric Double Oven
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2010 | Thermador SC302T Electric Double Oven
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
454 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
