Question about Panasonic KX-TG1033S Cordless Phone
I have a Panasonic Phone requiring 6.5VDC 500mA. The circuit inside the adapter has probably all 3 black capacitors blown. Can someone provide a circuit diagram for me to be able to fix the capacitors with correct voltage and microFarads?
Panasonic 3 red blinks
a capacitor has broken down, or blown up. my book states bad monitor.
www.ask.com/panasonic/tv/3/red/blinks/lights/mean/
Oct 06, 2015 | Panasonic Televison & Video
HOW TO TURN OFF MESSAGE LIGHT ON KX-T7433?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 18, 2014 | Panasonic BTS Panasonic KX-T7433 Black...
Panasonic PT-56LCX66 buzzing noise when i push power
I'm going to take a guess and say that the buzzing noise and burning smell was either a transformer or a blown capacitor (more likely). It's likely that your old lamp was still good and there is a problem at the circuit level.
If you or someone you know is comfortable with electronics, you may want to open it up and take a look. If there is a blown capacitor it will be obvious. Take a look at badcaps.net or Youtube for help on identifying them.
If you don't feel comfortable working on the inside of a TV it's probably time to get a new one. Repairs will not be cheap and they won't be worth it.
Jul 24, 2012 | Panasonic PT-56LCX66 56" HDTV
NET7452UC Electric Cooktop shows errors 26 and 42. What do they mean?
Problem: Error codes 26 or 42 after turning on too many heating elements.
Potential issue: Damaged main electronic board
Specific case: Error code 42 after turning on more than 3 elements, then already after 2, 1 until none of the cooking element could be turned on, over a period of a few weeks.
Root cause: Dying/blown electrolytic capacitor on the main electronics board.
Solution:
1) Turn off power (circuit breaker) - caution high voltage inside the cooktop
2) Lift the cooktop out of the hole in the countertop and slide it on a flat surface
3) Remove all screws around the metal housing using a torx screwdriver
4) Carefully tilt the glass top out of the housing on the front, noting that there are electrical connections in the rear, and place the rear end of the glass on a stable surface. You may need someone's assistance here.
5) After double-checking that there is no power, record the color coding of the four wires connected to the glass assembly (green for ground, white, black, red from left to right)
6) Next open the black plastic cover by removing four Torx screws.
7) Carefully remove from the connector on the left the the plastic strip connecting to the display board.
8) Carefully remove the circuit board with relays and capacitors that is held in place by plastic tabs.
9) If one of the capacitors is bulging out or showing sings of damage on top, replacing it may fix the appliance. De-soldering a bad capacitor requires some tools and skill. Replace the capacitor with at least the same capacity, voltage and use high-temp. 105C version) Alternatively, instead of replacing a $2 component you will have to replace the entire board.
10) Reassemble and done.
May 04, 2012 | Bosch 30 in. NET7452UC Electric Cooktop
I have a Polaroid TDA 03211C 32inch LCD TV /DVD COMBO screen went black cant get screen to work,sound works
It has 2 blown capacitors in it. Mine had the same problem. The capacitors are located at EC17 & EC18 on the top circuit board inside the tv. They cost about 1.00 a piece. You can get them at DigiKey.com. It is very easy to take the board out and have someone soldier the new ones in and then put it back together. You can fix it for about 40.00. Hope this helps. Do a search on line of what the capacitors look like........
Nov 01, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a Samsung SyncMaster 933SN 18.5 monitor. Just goes black
Very common with 2~3 years old LCD monitor is the failure of the DC filter caps in the power supply section, that will be your first place to look.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 21, 2010 | Computers & Internet
My ViewSonic VG2021M LCD computer screen has died on me. For the past two weeks it took 2 or 3 minutes to "warm up" before it would start working, and not it has completely stopped. Some have said that it...
I can easily see 4 bad caps (black case) with bulging tops, the other two caps (green case) should also be replaced at the same time, use only good caps, PANASONIC FM or FC series from DIGIKEY, higher value and voltage are OK to use. Learn more about what bad caps look like:
My pictures: http://s807.photobucket.com/home/budm/allalbums
Apr 02, 2010 | ViewSonic VG2021m LCD Monitor
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Feb 20, 2010 | JUMP START SYSTEM
IRiver H10
Require more history 1/condition of H10 battery B4 this problem (blown Charger Fuse) occurred 2/perhaps battery condition severly depleted creating high current draw upon initial charge attempt 3/not certain if an circuit protection fuse exists in H10 4/Chk charger wiring for shorts bare contacts etc.
Nov 27, 2006 | iRiver H10 MP3 Player
Panasonic KX-TG1033S Cordless Phone Logo
35 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
