Question about Kenmore Elite HE5t Washer
What does F25 mean on my Kenmore Elite HE5t washer ? It is making a loud grinding noise while it is spinning and stops in the middle of cycle and flashes F25. I took the back off and ran a cycle and watched it and I think I know where the noise is coming from and there is fine metal powder under the part the noise is coming from. Where can i get a repair manual?
  • 15,935 Answers
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
With the washer unplugged, locate the motor harness. Now unplug the motor connector to ohm the motor. Follow the list below to check the motor.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
* Pin 4 to5 115 ohms
If the readings are close to what is listed above the motor is fine.
Live voltage checks are dangerous, and possibly deadly. Exercise caution at all times. If you are not comfortable working with live electricity I suggest you call an experienced service technician. I have provided you with a wire diagram with what the voltages should be. If the voltages are correct I would then recommend that you replace the motor control.
http://media.fotki.com/1_p,ssqftgqdqbftqgbxgtqsskgwtqkq,vi/sbbsgkqrgxstbrqrgwf/1/1303472/5961857/image5533851340308453439img-or.jpg
http://media.fotki.com/1_p,ssqftgqgtstgdfrxgtqsskgwtqkq,vi/wwkfkbqwwxkftrskdkw/1/1303472/5961857/image1769329000959650960img-or.jpg
http://media.fotki.com/1_p,ssqftgqbrdddksdxgtqsskgwtqkq,vi/stbrqrgwfxsbdkgqfbr/1/1303472/5961857/image5269611314094350944img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 18, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Washer makes loud noise (seemingly unbalanced) while spinning
Suggest making sure all four (4) screw leg adjusters are set correctly i.e. does it wobble if you shake like a "pin ball machine", when not in use? If yes, adjust the screw legs in each corner. To ensure the machine is sitting level and not able to shake... God Luck
Apr 21, 2011 | Kenmore Elite HE5t Washer
My Kenmore Elite top filling washer 22952 100 spins as its filling with water and makes a loud grinding noise as it changes cycles
chances are there is a piece of broken glass in the bottom. Happened to me , found out a glass had broken and pieces were causing a grinding noise.
Jan 29, 2011 | Kenmore Washing Machines
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Kenmore Elite HE5t Washer Logo
1,036 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
