Just bought a used Toshiba Satellite P35 S6112 laptop. I installed a good hard drive, ram, and it started right up. No picture or sound. I connected a external screen and it said it was receiving nothing. Clicked fn and f6 & f7 and nothing happened. I could tell that XP Home Pro was running. Fans got loud but laptop did not shut off. When I clicked the on/off button unit immediately shut down (not slowly) as it would normally do while saving your settings. Any suggestions? Thanks, Jim J.
  • 3,083 Answers
Couldn't find any reference to this problem on the net, so it's probably just an issue with the video card, since this is a high-end gaming machine, and was probably using the video card a lot, to the max. Sounds like the laptop is booting up, but no video output. If nothing comes up with the function keys, that's probably the lack of a video signal.
I did find that there was a recall on the batteries on some of these machines, and that might be of interest to you, here's the link:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=973928&rpn=PSP30U&modelFilter=P35-S6112&selCategory=2756709&selFamily=1073768663
You might call around to some used computer shops, to see if they have a spare card.
Sounds like a nice machine, and worth trying to get it running, especially since you've already put a bit into it.
Good luck to you, and hope this helps.
Posted on Aug 05, 2010
My laptop will not boot blue screen message *** STOP:0X0000007B(0XF78D2524, 0XC0000034,0X0000000,0X00000000) Do's this blue screen message mean any thing to any one!
Dear, I am not good blue screen code reader. But I guess (from my experience) this can happen in case of defected ram, hard disk or trying to install operating system which is not supported by the motherboard or laptop.
You can try to load changing ram for testing purpose with a good RAM if does not work, try to Remove and install a good hard disk then go for the loading. I think by loading you mean start up your laptop booting form your hard drive. If so, just try to re install your operating system. Let me know updates.
Jun 25, 2012 | Toshiba Satellite P35-S611 Notebook
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Got white vertical lines on left side of display
          Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
          Jul 21, 2010 | Toshiba Computers & Internet
          Hi since I installed windows 7 in my toshiba satellite P35-S605 pc I haven't been able to use my tv as screen. What do I do? Thanks
          You need to configure it as a second display. Connect the tv to the laptop, right-click on the desktop and choose Screen resolution, select the 2, put a resolution supported by your tv and select the Extend option.
          Jul 01, 2010 | Toshiba Satellite P35-S605 Notebook
          Toshiba Satellite P35-S609 xp System - hello is there a service manual for this product?
          Go to Toshibas website and you can get it off of their website.... Or google "Get Manual for Toshiba P35-S609 Laptop"
          Good luck Hope that helps
          May 21, 2010 | Toshiba Satellite P35-S609 Notebook
          Won't stay running
          Update the Bios Driver for the computer off of toshibas website and it should fix it, I had the same exact problem!!! And if that doesnt solve the problem you have a bad battery...
          Feel free to Email me with questions at newlook_inc@hotmail.com
          hope this helps!! Good Luck
          Jeremy
          Sep 24, 2009 | Toshiba Satellite P35-S609 Notebook
          Slow Hard drive
          That model is only IDE capable and has no SATA ports on the motherboard. You should get a faster IDE harddrive OR an external USB harddrive .
          May 08, 2009 | Toshiba Satellite P35-S611 Notebook
          Hard drive and memory
          the laptop should pick up a 20gb or 60gb ide hard drive with no problem
          Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
          Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
          Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
          Toshiba p35-s609 laptop
          Sounds like you have diagnosed your own problem to me. Its not the video card or you wouldn't be able to use the monitor, so it has to be a bad switch. If you can remove the bezel covering the switch you my be able to spray some contact cleaner into the switch and get it working again. Removal of most bezels starts with removing the screws on the back side of the lid hinges and lifting the bezell until it un-snaps from the housing.
          Good luck. let us know how you make out.
          Jan 06, 2008 | Toshiba Satellite P35-S609: Pentium 4-3.2...
          Computers & Internet Logo
          26 people viewed this question
          Alun Cox
          David Payne
          David Payne
