Question about Maytag Washing Machines
I am getting F35 code in digital display on Model MHWE500VW front load washer.
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
SOURCE: He5t Kenmore ELITE front load washer flashing f35 code
I hate my machine. Just over a year old, F35 failure code. Wish I still had my reliable Maytag. And this failure is on a machine that replaced the FIRST one of these **** I bought. So I've had not one, but TWO units fail within 15 months of purchase! Anyone else have this miserable experience? What a total sham these machines are. Sears is less than supportive of their "flagship" product name.
Posted on Jun 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
craig6773
  • 116 Answers
SOURCE: We keep getting an f35
First of all, be sure you are using only HE detergant. Your drain filter is likely clogged and needs cleaned. On the front lower panel of the washer, remove the screws and panel. You will see a drain filter (about the size of a tennis ball). Before removing the drain filter you are going to need to hand bail the water out of your drum or all the water will run out when you remove the drain filter. Slid a plastic trash back up under the drain filter to help contain whatever water you could not bail out by hand. Remove the drain filter and clean it thoroughly. Replace the drain filter, replace the lower front panel and run a rinse and spin cycle. If sudsing error continues and you are using HE detergant, you may need to lower the amount of detergant you are using. However, 9 times out of 10, it is just the clogged drain filter.
Posted on Nov 26, 2010
SOURCE: Suds and F35 keep shuting down my laundry day:(
I followed the suggestions of opening the lower panel and checking the filter. I found it completely clean but the machine still gave me the SUD code .... so, I detached the hose and blew it out. There was nothing more than still water in it but after running water through it and reinstalling it, the machine work fine once again.
Posted on Jul 17, 2011
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
Getting an F35 error message on a front loading kenmore washer. Any suggestions?
This link should help:
http://www.managemylife.com/mmh/questions/123674-does-f35-error-code-indicate-kenmore-front-load-washers
May 20, 2011 | Kenmore Front Load Washer
Error code F35
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer. I am not aware of other uses of the F35 code on the various models. If you intend to diagnose and repair this problem yourself, I recommend resubmitting your question with the full model number of your Kenmore washer so that we can verify this technical information using your model number.
Jun 08, 2010 | Kenmore HE2 Plus Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Model: wfw9500tw01 f35 error
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Washing machine error codes
I am getting F35 error code. What is the problem?
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
