Question about Craftsman Saws
I have a Craftsman 10 inch table saw and it doesn't have a on/off switch, I can't find the service manual to wire the proper switch in. Model #113-12006.
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
SOURCE: Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Posted on Dec 04, 2009
I found a Craftsman 9 inch table saw, Model 113.242720 and the capacitor was missing and switch was not wired up. I can't find a clear wire diagram for this anywhere. Do you know how to get one?
This is a very old tool, relatively speaking. View the owner's manual at https://www.manualslib.com/manual/495271/Craftsman-113-242720.html, but you're on your own for wiring. Your best bet would be to remove the motor and take it to an electric motor service center (check Google for a local motor shop) and have them set it up for you.
Dec 27, 2017 | Craftsman Saws
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Wire diagram for craftsman 10" table saw
Hi there.
Prior to plug it try this.From your 3 prong grounded plug trace it up to your saw were you should have a black and a white from the same wire's end.Now the two whites are probably from the reset that you haven't replaced?Write back to let me know if this is right and I'll proceed.
Jul 25, 2013 | Craftsman 10" Table Saw
Looking for Craftsman Table saw Owners manual for model 137.271340
I found a very similar model number on the sears site, on the chance that you misread (or mistyped) the model number. I found the 137271140. Follow the link below, click on the "Search by part description" tab and type in "manual"
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-137271140/0247/0744600?blt=05
Please vote if you found this helpful. Good luck, Al K
Feb 16, 2011 | Craftsman 10" Table Saw
I need an instruction manual for a Craftsman 10 inch table saw model nmbr 315.228110
A pdf OM can be found at this link.
http://www.managemylife.com/mmh/owner_manuals/13651/CRAFTSMAN-Saw-Table-L0060173?brand_name_search=315228110+CRAFTSMAN
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 31, 2010 | Craftsman Saws
I'm missing a ''tilt'' set screw on my Craftsman 10 inch table saw
I couldn't find that model Sears saw to confirm, but if yours is like mine (113.298720), then the handle on the right causes the saw trunion to swivel left and right. And there is a locking hex-head bolt on the front of the saw up close to the underside of the table. This bolt locks the trunion in place keeping it from swivelling.
Take a look at the following diagram http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/P0908018-00004.png part 22 is the shaft that tilts the blade Part 30 is the bolt that locks it in place part 29 is the handle part 28 is the spring that holds the handle on the locking bolt
Mar 19, 2010 | Craftsman 10" Table Saw
Just purchased a used craftsman 12'' commercial table saw model # 113.29930 just looking for a service manual
I have a paper manual for a 113.29970 12" direct drive, probably the same basic saw. I sell craftsman table saw parts on ebay as "hokienpokie" or you can contact me via email too, Jim
Feb 05, 2010 | Craftsman 10" Table Saw
I need to replace my table saw switch assembly
I am not getting either # from sears parts. I deal in Craftsman Belt drive table saw parts. I should have a switch that would work for you. Can you send a picture? jimatcavanaungh@cs.com
Nov 03, 2009 | Craftsman Saws
I need a manual for a very old cast iron 10 inch sears craftsman table saw. Sorry, no model number
Have a look here. Given the lack of a model number, that's the best I can offer, I'm afraid.
Good luck.
Aug 31, 2009 | Craftsman 10" Table Saw
Saws Logo
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Tim Venetis
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
