Question about Maytag Neptune MAH5500B Front Load Washer
Doesn't spin out. Says L r on diplay - Maytag Neptune MAH5500B Front Load Washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Posted on Aug 06, 2010
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
Drains but drum wont spin
see this probably causes:
t spins, but doesn't pump
see for glogged drain line
It doesn't spin or pump
see the pump pulley frozen
It pumps, but the water returns
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
I'm getting an OE error on my LG washer diplay
You are likely using the wrong kind of detergent and the suds are not being washed away.
Use high-efficiency detergent and/or lessen the amount of detergent you are using.
Jun 05, 2009 | LG WM2487H Front Load Washer
Smoothfitness 7.1hr would not run
Sounds like the motor is stuck or bad. Get into the front panel near the roller and remove that cover and check it with a volt meter
May 16, 2009 | Smoothfitness Smooth 5.45 Folding...
Maytag Neptune MAH5500B Front Load Washer Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
