Question about GE Slim Spacemaker 7-5295 CD Shelf System
I have a ge spacemaker model # 7-5302 and every night at midnight it alarms I don't know how to stop it frm doing this. could you help. Gloria
JMuskovitz
  • 135 Answers
SOURCE: Faulty Alarm
Per the second review at this site: http://www.amazon.com/75290-Spacemaker-Player-Built-Subwoofer/dp/B000051SEK "And if an alarm sounds at midnight, UNPLUG the radio's power cord from the wall receptacle, WHILE that alarm is sounding. Wait at least 20 seconds, and re-plug to power. Sleep in heavenly peace!" Perhaps this will do the trick? If not, the phone number to call is also listed in that same review. Good luck!
Posted on Mar 25, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
Posted on Jun 08, 2008
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
  • 18 Answers
SOURCE: GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Posted on Nov 21, 2009
Testimonial: "thanks. I just hate to replace whole unit but it looks like it is going to cost 125 for magentron and 100 for service call plus. "
How do you operate the alarm?
Start by adjusting the volume down to an acceptable level.
The mere fact that midnight is the HOUR of YOUR SCHEDULED assault... means you have SET the TIME but have never set the ALARM clock... and are using it mainly as a clock only... Yes?
Not as a radio... (I don't know your model... but most radio alarms are at your regular listening volume... (my sheltered opinion)).
(trying to be Sherlock here).
So you probably have your
ON - Off - Radio - Alarm selector switch set to RADIO... Yes?
I'm guessing... That is the problem.
When you want to listen... use the sleep or on buttons... or the "ON"
If I am off the mark... "comment" back to me with the MODEL & MAKE... and I'll give it a better going over.
Peaceful sleep is nice.
Jan 06, 2016 | Audio Players & Recorders
The buzzer goes off at 12 midnight every night
You probably have an alarm feature on the radio.
The common default time for timepieces is 12:00.
Find the alarm setting and set the alarm off.
If you cannot turn it off set it for 11 am.
Aug 29, 2011 | GE 7-5290 Clock Radio
How to switch auto alarm on and off just how to set alarm and disable and enable product is a sainsburys red dab clock radio not the one with docking station
Dont know how to set the time for the alarm, but to switch it off press and hold the menu button until it asks if you want to reset the radio and then follow the instructions. It means you have to reset radio every time but at least it stops pesky alarm going off...
Nov 15, 2009 | Audio Players & Recorders
Our radio automatically turns on at midnight. I
Your radio must have an alarm switch that will allow you to choose between radio and buzz. I'm sure you
will find it. Just take a good look.
Oct 04, 2009 | GE Spacemaker (74290) Clock Radio
Midnight alarm feature never seen before
I am having the same problem. IT's so weird because I had owned the radio for many years before this ever happened for the first time? I unplugged it and this solved the problem for several months and again all of a sudden I am woken up every morning at 1 am. Any long term solutions?
Dec 01, 2007 | GE Spacemaker (74290) Clock Radio
Faulty Alarm
Mar 24, 2007 | GE Spacemaker 75290 CD Shelf System
GE Slim Spacemaker 7-5295 CD Shelf System Logo
Top GE Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jim Goldsmith
Jim Goldsmith
john1959ny
john1959ny
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
