Question about Linksys Wireless-G WRT54G Router
I have the Linksys WRT54G router hooked up thru Ethernet to my desktop PC with Windows XP. I go thru a cable modem to the internet. I have 2 laptops, both with Windows Vista on, wirelessly linked to to the router. Often, after my friend uses her laptop, the network goes down. When I use the Advisor, it tells me a different network is detected and I have to disconnect the modem and router to reset. That hasn't happened with my laptop. I am also able to use my IPod without issue. Any suggestions as to what may be going on?
  • Linksys Master
  • 7,733 Answers
Low or poor signal is mainly caused by the following major factors:
Going Around Physical Obstructions
Wireless networks are also susceptible to obstructions that may lead to low signal. Often, the signal gets reflected, refracted or absorbed by the obstruction.
Common obstructions are:
  • Cabinets
  • Mirrors
  • Glasses
  • Metal objects
  • Thick walls and ceilings
If you have any of these objects between your wireless adapter and access point, consider relocating your access point somewhere high to get around the obstruction.
Posted on Oct 29, 2010
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
No internet connection...
Check your cable-connections:
AC power to the router.
Cable-modem <----> WAN-port on the router.
or
DSL-modem <----> WAN-port on the router.
LAN-port on the router <----> Ethernet port on your computer.
Windows 7 should show that you have obtained an IP-address,
starting with '192.168.' that was supplied by the router.
Note that some ISPs (Internet Service Providers) will require
that you tell them the MAC (Media Acccess Control) address
of the _ROUTER_ before the router will be able to connect,
through the ISP's services, to the Internet. Contact your ISP.
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Dont no how to hook up wires to modem
Its very simple...
Take the ethernet cable from your modem, and hook it to the "internet" connection on your router.
Then take another ethernet cable and run it from your computer to any of the other ports (1-4).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Nov 08, 2009 | Linksys Wireless-G WRT54G Router
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
