Have rca model 20v412t in an rv. Was ok last week but just turned on and picture has too much red in it. Tried adjusting and no difference. Checked and cleaned all cable connections and still the same. R.V. has a booster switch on antenna. Have small tv in front of rv and it is fine. ????
Rca tv model 20v412t.letters are double, colors look like a rainbow.Is this a serious problem?
Posted on Mar 18, 2010
Tv come on but cant clear the picture from turning red and black how can I get a clear picture?
Without knowing anything about your Tv make or model this is hard; but there should be a reset button in your menues to restore all settings to factory default. Find and use that. However I am suspicious and think the set needs reapir.
Jan 02, 2015 | Televison & Video
I just need to adjust the resolution on this TV. NO ONE at RCA could seem to help me. Thank you.
hi,
did u mean to adjust the picture setting then go for the following
1 press menu on the remote
2. using down arrow select picture quality and press ok. available options in picture quality and its use is listed below. you can use it according to your preference.
Basic Picture Control- Displays the five slider controls for adjusting
the way the picture looks.
Contrast Adjusts the difference between the light and dark areas
of the picture.
Color Adjusts- the richness of the color
Tint Adjusts the balance between the red and green levels
Black Level Adjusts the brightness of the picture
Sharpness Adjusts the crispness of edges in the picture.
When exiting this menu, the Save Personal Picture Preset choice list will
appear. You can choose either Yes or No. If you save the settings as a
Personal Picture Preset, the TV will store the settings so you can reselect
them easily if someone changes the settings.
Picture Presets Displays- a choice list that lets you select one of three
preset picture settings: Bright Lighting, Normal Lighting, Soft Lighting
or Personal Picture Preset. Choose the setting that is best for your
viewing environment.
Auto Color Displays- a choice list that lets you turn on the feature that
automatically corrects the color of the picture. (This is especially useful
for tracking realistic flesh tone colors as you switch from channel to
channel.) Choose On or Off, depending on your preference.
Color Warmth Displays- a choice list that lets you set one of three
automatic color adjustments: Cool for a more blue palette of picture
colors; Normal; and Warm for a more red palette of picture colors. The
warm setting corresponds to the National Television Standards
Committee (NTSC) standard of 6500?K.
Video Noise Reduction Displays- a choice list that lets you turn on the
feature that automatically reduces noise from the picture. Audiovariable
enables the TV to automatically adjust noise reduction level;
off turns off noise reduction feature; on-fixed sets a fixed level of noise
reduction.
Dec 21, 2010 | RCA G36705 36" TV
RCA Model D61130 Picture is now Green and Dark
yeah mine to,, ive found out which ever direction the color is goin out of line,, when u get 2 the convergence screen,, dont push ok,,push the direction the colors r messed up,, should help u,,good luck
Aug 16, 2008 | RCA P61940 61" Rear Projection Television
RCA P61927 NO POWER!!! HELP
If it is a ctc or ptk 195 then you have a bad flyback High Voltage transformer: the large white kindof square thing with big red wire coming out; Must get original RCA part. If picture was good before could cost you a total of (average) $300.00 according to which repairman.
Dec 14, 2007 | RCA P61927 61" Rear Projection Television
No Colour when playing DVD
  1. Was the DVD player hooked up correctly?
  2. If only black and white then check the video output in back
  3. It maybe on the Y. Pb. Pr check to see.
Nov 25, 2007 | RCA F19430 19" TV
Sylvania 6842PF M screen turning dark red
This sounds like the color processor IC is not working properly. If this is the case you will have to have this checked by a qualified technician.
Sep 21, 2007 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
