Question about Maytag MAH2400A Front Load Washer
Maytag MAH-24 door won't open
Lots of noise, and no action. Machine doesn't work. Sounds like it's trying to spin. The noise is like a coin sorter at work.
I tried powering off and waiting to get door open and get the clothes out, but no luck.
    Novelist:
  • 166 Answers
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Nov 12, 2008
2 Suggested Answers
  • 63 Answers
SOURCE: Maytag MAH-24 door won't open
sounds like something in pump go there first
Kenmore oasis makes loud noise when spinning
You can check the shock absorbers, maybe is not in good conditions.
Dec 23, 2017 | Maytag LAT3600A Top Load Washer
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Does sound like it's not balanced properly, or maybe it's set on drip dry instead of spin , basic solution i know but often the best lol ,
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Its a commercialcoin operated machine that won't start washing what could be the problem please?
open the coin dispenser and push in the start button that the coin lever should push in when you put the correct coins in the dispenser
Feb 04, 2013 | Maytag Washing Machines
The washer ran fine then stopped with water not draining. When I push the on button I get a buzz or humming noise .nothing moves. There is no error code.
Sounds as if you have something doen in the pump preventing it from draining and in doing so shutting the machine off as a safety action. I think you can actually access the pump from the rear of the machine. just unplug the machine, prepare to get wet, take the back of the machine off, take the lines off the pump and check for the blockage.
May 27, 2012 | Maytag MAH6700AWW Neptune Front-Load...
My Maytag MAH-24 Washer suddenly started making a clunking grinding sound in the middle of the spin cycle.
The rear tub bearing is going out, and the cost starts normally about the 450 and up range,
May 27, 2012 | Maytag MAH2400A Front Load Washer
Maytag front load mah-24. no error codes. humming at any slection but nothing else.drum is not jammed, can manually spin it. won't fill,spin or anything.
Sounds like a belt problem. you can take the back off of this machine to see the belt and the motor. There is 3 screws on the back cover 2 on the rleft as you look at the back of the machine and 1 on the right. remove these to get a look at the belt and motor.
Dan
Aug 10, 2009 | Maytag MAH2400A Front Load Washer
Maytag MAH 24 does not drain and makes weird humming noise
i also have this problem. to get the door to unlock, just unplug the washer and it should open in a min or two. you will hear a click. you may have a mini flood but at least you can get your cloths out and bail out the water. my problem started when i began using a new detergent from Tide called total care. Still tying to get the pump to work.
Jan 25, 2009 | Maytag MAH2400A Front Load Washer
Maytag Neptune Front Door Load, Problem
Hello Yery1975
Welcome
You said, you have a situation with my washer machine (Maytag Neptune front loader). It was making the noise several times as latching the door, then if would go off and you could not open the door, You found the under soap deposit cord but the situation is not opening the door or no, it is getting he machine to work. Whichever cycle you press, the door makes the locking noise several times, sometimes the door can not be opened and the lock door light is off, the thing is that whichever cycle you try the numbers on the electronic pad would go down several numbers and then it will again make the door locking noise and will stop there, the start button begins flashing and the machine does not wash at all on any cycle, neither it spins or rinses. Can you please, please, help me? Ohooo... some times after trying and trying get the FL code... you have tried keeping it disconnected from the electricity for long periods, plugging it back and all you can think off.... but nothing!!!
You did the right thing
The Maytag Neptune had a lot of very different defects that Maytag was, and is aware of still.
That is why they discontinued that model .
But if you call Maytag service this time, you may find that it will be one of those defects in their design and an authorized Maytag person will recognize which fault is taking place.
perhaps they may cover the parts if you bring it to their attention.
Thank You
Please remember to leave a rating
Oct 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Aug 16, 2008 | Maytag MAH2400A Front Load Washer
Spin cycle noise
coins inbetween bowl can be a problem
try tacking machine outside empty of all water
tip upside down sometimes gets the coins out
otherwise you need to pull machine apart
try another way
remove from bellows from machine and turn bowl by hand to remove coins
have fun
Jan 05, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag MAH2400A Front Load Washer Logo
303 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
