Question about American Standard Home
Very slow drainage of a small bathroom sink. Liquid Plumber does not help
    Scholar:
  • 122 Answers
Probably hair stuck in the drain. did you remove the stopper "pop up" if no hair or blockage there or in the trap, then its further down, you will need a small snake. 1/4 inch cable works well in bath and kitchen drains.
you can purchase one at home depot.
Posted on Aug 15, 2010
Hi there i have a lunnar delta 2004 640ew im trying to find a new replacement bathroom sink have you got any ideas where i can get 1 from many thanks tim
ring around plumber whole sale suppliers and explain what you want
they are in a position to advise you where or if what you want is still available
Jul 19, 2016 | Moen Bathroom Sink Faucet - 4-inch...
Slow draining kitchen sink
You may have to call a professional or, if it were me having this problem, I would keep trying the Liquid Plumber or even Drano. I have found that the foam versions work best, but you may have to try it more than once. In a 14 year old building that has never had plumbing done, there could be a really bad clog that only a professional can handle. I hope this helps.
Jan 11, 2012 | Dishwashers
I am installing a Blanco cafe brown sink basket strainer. The directions state that a thin bead of silicone, not plumber putty, goes at the bottom of the sink hole. Is this accurate?
Yes The Blanko is installed with silicon not plumber putty. This is common with the newer sink strainers
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Aug 15, 2011 | Blanco Sink Waste Strainer / Stopper...
Bathroom cold water faucet makes a drumming sound in the pipes when turned on. It makes a broombroombroom noice that is worse when all the way open. The water will also alternate between high and low...
you have air in the water lines try going to your water heater and lift the pressure relief vavle slow hold open have hot water valve on sink on let water run till water comes out pressure releif vavle make sure water heater is off and cool first
Aug 10, 2009 | Plumbing
Plugged dispensor of the liquid soap at kitchen sink.
soak it in hot water and try pumping it every so often,should loosen liquid soap.
May 25, 2009 | American Standard Contemporary Kitchen...
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Clunking noise in sink
You are describing a problem known as water hammer. This will ultimately cause damage somewhere in your plumbing system so it should be addressed. If you are handy you can install an air chamber near the sink. If you want more information let me know. good luck.
Jan 17, 2009 | Home
Home Logo
293 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
