In middle of cycle washing machine flashes error code2! And i can't continue to wash. What does this mean? Necht make.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the manufacturers name and model no# of your washer, also please elaborate your question so that I can assist you further.
Thanks
Rylee
Posted on Aug 05, 2010
How do I fix an 03 error on my siemans siwamat 6125 washing machine?
going into unbalance? would check my counter weights as they may be going bad
Feb 26, 2015 | Washing Machines
How to fix nd code
ND means no drain. The issue could be using the wrong detergent. IT could also be something stuck in the filter or the pump.
Aug 05, 2017 | Washing Machines
Error F11 during the wash cycle
The error means that the controller is not talking to the other components. It is very expensive to repair,. If you want to run tests on it, there is a tech sheet behind the kick panel under the door.
Feb 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Just hada brief power flash. Washing machinbe was on. Now just keeps beeping with E60 lfashing on the screen. Not continuing cycle. Can't open door. Can;t re set
The E60 is not listed but it means the cycle was interrupted due to a fault with the motor.
You don't provide many details about what is happening or when the code is displayed.
Try to run a drain and spin cycle and see if the motor will turn.
The E60 error most likely means there is a problem with the motor.
Mar 13, 2011 | Washing Machines
F 70 is flashing ???
Error code 70 means a Central Control Unit Heartbeat Failure. There is no
communication detected from the Central Control Unit to the
User Interface (the part that you touch in the middle to set cycles).
Possible Causes/Procedure
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and
the Central Control Unit.
Nov 26, 2010 | Whirlpool Washing Machines
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
WF320P Water fills on wash cycle drum starts to rotate. After 30 seconds or so middle three red error lights flash and cycle stops.
Hi there swamib lets see if we can help you out. If the lights in the middle of the appliance flash led 1,2,3 that means there is a problem with the heater it is most likely it is open circuit replace this and it should solve the problem keep in touch noffie......
Apr 08, 2008 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
