Question about Hayward SAND FILTER, PRO SERIES
The handle on the multi-port valve S244T filter is loose (it offers no resistance to being moved up & down). However changing port is exteremely difficult and requires two hands. What is causing this?
  • 8,404 Answers
Up and down is the locking mechanism. You should only move the handle in a clock-wise direction.
I think you should take the valve apart ... clean thoroughly ... replace the gasket and lubricate with what ever your Pool Supply place recommends.
I hope this helps you ...
Posted on Aug 06, 2010
Testimonial: "Thanks for the recommendation. That is exactly what i ended up doing and it fixed the problem"
  • A Miller Aug 07, 2010
    I am so glad to hear this news ... enjoy your pool.
    Thanks for the 4 thumbs up
This is the 2nd summer we have used our Hayward pump all of a sudden it pushes water into the pool for filter but when set to backwash or waste it hums for a minute then throws the breaker
Need more info, model and over all condition. I would check the capacitor on the motor first and then the multi-port valve. Make sure you are shutting the pump off when moving the handle on the multi-port .
Jun 19, 2017 | Hayward Pool & Spa
How do I make sure I reassemble my Hayward sp0714t
Hi This is John the Hayward tech. I have attached a link to the manual for the 2244T. Not sure if you took the valve apart or have taken the valve off the filter and just need to put it back on. Let me know if the manual helps http://www.hayward-pool.com/pdf/manuals/ProSeries-S180T-S210T-S220T-S244T.pdf
Sep 01, 2014 | Pool & Spa
Hayward 220T pool filter is leaking water; could it be the multi-port valve needs to be replaced?
if coming out of top where handle is yes if out backwash line yes make sure unions are tight also
Dec 30, 2013 | Hayward SAND FILTER, PRO SERIES
Variflo valve SP 714T..I changed the diffuser with seal attached..filter when it is in the filter position, pumps water out of the back wash port. Tried rotating handle and bumping it down..sprays water...
You just installed the handle backwards when you put it on....backwash & filter are 180 degrees opposed.
Take it apart, push the pin through and rotate handle 180 degrees before you reinstall pin.....no worries.
Jun 19, 2012 | Pool & Spa
I have a hayward S244T sand filter and the lettering on top of the handle is gone and I don't know anything but filter and backwash I would like to know if it has a recirculte position and where it is on...
Thank you for posting your question here on Fixya.com.
The 'manual' for their multiport valves, found here, shows the layout of your settings.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jul 30, 2010 | Hayward SAND FILTER, PRO SERIES
How do you replace the handle on the control valve pro series sa
Is this a push pull valve or a multi-port?
Push Pull --- there is a screw in the edge to remove that will allow you to pull the assembly from the housing.
Multi-port --- 6 screws around the ring to remove.
of course --- turn the pump off before you do anything!
I hope I have answered your question.
Jun 02, 2010 | Hayward SAND FILTER, PRO SERIES
Need to know how to backwash the pool filter
Depends ...
There are two primary valve styles ... a "multi-port" and "push-pull". Never change a valve setting with the pump running.
Multiport has a handle that goes around in a circle (only move it clock-wise). You should go to your pool place to identify this kind of valve and get new lables. Push-pull goes up and down. Up is filter - Down is back wash.
If you will study your system, some things will become evident to you .
Your pump pulls water from the pool through the pump ... out of the pump into the filter. Through the filter, back to the pool. You might be heating the water (would be after the filter) and you may be adding sanitiser (after the heater). One suction - two discharges (oh, the other discharge is to waste.).
Recap ... water out of the pool into the pump - out of the pump throuth the control valve to the filter - out of the filter to the heater then to the sanitiser then back to the pool.
Any help?
Thanks for your interest in FixYa.com
BTW ... I am a volunteer question catcher at FixYa.com. At my job, among other things, I am a Certified Pool Operator (CPO), certified by the National Swimming Pool Foundation.
May 14, 2010 | Pool & Spa
Hayward S244T filter spraying water at top
Just an o-ring and the 2-piece clamp that compresses the two pieces together.
Jul 28, 2009 | Hayward SAND FILTER, PRO SERIES
Multi valve stuck
u may need to replace the spring under the handle. u can also replace the whole handle assembly for around $40.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
536 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
