Question about Car Audio & Video
2003 Honda Odyssey....radio showing code E or error code,, how can I reset this myself ? thanks !!
lexzy80
  • 943 Answers
SOURCE: CODE RADIO MUSICA HONDA ODYSSEY
You can obtain the code from the manual booklet that comes with the vehicle and then go through it., You can find it under the radio section.
If you can't find it there. you can check the security booklet if you find it there.
You can also call your car dealer and ask him about it.
Hope this was helpful?
Posted on Jan 03, 2011
maklean
  • 1665 Answers
SOURCE: CD Player / Radio Error Code
see a relative link
http://www.hondacarforum.com/honda-3/22348-2000-honda-civic-radio-error-code-problem.html
Posted on Jun 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: radio code for 2003 honda pilot, and reset for maintanence light
There is a little fuse box to the left of the steering wheel with a cover over it. When you take off the cover on the under side of the cover there is a big number (like big font size) printed on a piece of paper. It like 5 or 6 digits long and obviosly numbers that can go into your stereo, like 1-6. If you type it in and it works it will make a beeping sound.
If that doesnt help, call your local Honda dealership and get the code from them. You can also obtain a user manual. All the needed info can be found on this page:
http://automobiles.honda.com/information/owner-resources.aspx
Posted on Jul 01, 2008
dsacco86
  • 1077 Answers
SOURCE: P0740 code showing in my 2000 Honda Odyssey
P0740 Torque Converter Clutch Circuit Malfunction
The problem could be the torque converter itself or the sensor circuit for the clutch.
Best to have a Transmission Expert look at it to see if any further damage has occurred.
Posted on Apr 19, 2009
jmgldsmth
  • 2005 Answers
SOURCE: honda odyssey ex-l radio not working. had to jump
go to the dealer with your registration , ownership papers and, vin# the dealer will reset it
Posted on Sep 05, 2009
Honda odyssey 2003 CD player shows E 00 w hen I try to load cd
E00 is a vague error code used by Honda that indicates a problem with the CD Drive in the head unit. Unfortunately this will require removing and head unit and replacing it with either an OEM replacement or an aftermarket unit.
Apr 05, 2015 | 2003 Honda Odyssey
My odyssey 2003 is showing code err for the entertainment
Does the radio work at all. or is the cd player the only issue.? most of the time you need to enter a radio code to unlock the radio. If you enter it wrong to many times it will display error on the display.if you dont know the code then you can call the dealership and get the code after you do the following below to get the serial number.
Press and hold 1 and 6 on the radio while still holding the 1 and 6 press the power button. At this time it will read off serial number
SOUTHERNELECTRONICS.COM
Apr 02, 2015 | 2003 Honda Odyssey
I changed the bettery in my 2003 Honda Odyssey and now the radio won't play, it asks for a reset code. How do I find this code to reset it to play ?
Inside the glove compartment on the left hand side there should be a series of numbers under 6. You punch in the order on your pre set radio station numbers and it should come right on! Good Luck!
Jan 27, 2011 | 2003 Honda Odyssey
2003 Honda Odyssey DVD will not eject disk. How do I fix this?
Replace it with a repaired unit or yours repaired for around $350 and labor unless you know how to remove it yourself. Honda has a repair service in Cal.to fix these problems. Here's an idea, I got one from a wrecked Odyssey and installed it myself. Doesn't require a code number as it is programed in radio.
Aug 12, 2010 | 2004 Honda Odyssey
Radio not accepting manufactur code.
If it is the correct code, you may have entered it a few times & locked the system. Either disconnect the battery & wait a minute & reconnect & retry, or pull the radio fuse & retry after waiting a minute & reinstalling.
Feb 14, 2010 | 2003 Honda Odyssey
Resetting radio code
You need to be very careful Each failed attempt causes a long delay before you can enter it again. Follow the instructions exactly. You may need to use the car for a day or more before attempting it again if you failed too many times. The radio should say CODE not ERROR. Error means no code can be entered now. You must wait until the radio displays CODE.
Feb 07, 2010 | 2002 Honda Odyssey
I have a 2003 Honda Odyssey my radio says code
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.)
. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Hope this gets you started on getting it playing.
Nov 12, 2009 | 2003 Honda Odyssey
Radio locked on purchased vehicle
To reset from ERROR 7 leave it SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself.This could be several hours.
Make sure you have the correct code.
Unfortunately Honda codes are very difficult to obtain for free from anywhere ...so try here first (for free)
https://radio-navicode.honda.com
If they cannot provide your code then you will have to try your HONDA Main Dealer or a Decode Service who will plug it into a laptop and electronically read/recode the memory chip (EEPROM)
Oct 03, 2009 | Vehicle Parts & Accessories
Blown fuse
go here this should help
2002 honda odyssey
let me know how you do and if you need more info
later paul
Nov 11, 2008 | 2002 Honda Odyssey
Car Audio & Video Logo
273 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
