Question about HP DeskJet 890c InkJet Printer
Does not print
I have a homenetwork with one xp computer and a vista computer. Since yesterday the printing via the vista computer fails whilst it functions well via the XP computer.It has functioned in the past and the printerstatus is indicated as false. on the vistacomputer
  • 1 more comment
  • Bubbel Apr 27, 2008
    After several attempts the problem was solved. Thank you for the quick help. Until the next problem Grtz Bubbel
  • plofre Sep 11, 2008
    Same problem - but there is no driver for DeskJet 890c for Vista! Where did you find that? Can you post a link?
  • Anonymous Sep 29, 2008
    My 890C started to accept a request to print a test page. However, nothing happened. When I tried to clear it, the printer continued to seem as if it was going to start (the yellow light flashed on and off) but again nothing happened. I turned it off, disconnected it and restarted it, but each time, the yellow light flashed, but nothing happened. It is as if it wants to print and has the instruction in its memory, but cant actually print. Is there any way to re-set the printer?
  • 487 Answers
Delete the printer form your printer list
re install with the driver which you can get from the support section from HP specially for vista. Easy fix
Please rate me
Posted on Apr 26, 2008
I cant plot from AutoCad 2006, using My hp
hmmm.. we only have two computers at my work connected to a router. the designjet has a network card going straight to it. i connect to the router wireless and it reads vista. my boss connects to the design jet thru the router as well with a network card rj cable with xp pro. as for our printer it can be connected via router and does work fine but my boss has it directely connected to his computer and i share it off of his system. then we also have a zerox machine connected via router as well. maybe your router is going out? try a new one or a better one and see if that fixes it. it maybe defected or time for a new one.......
if it was working before then maybe its the router.
Jan 07, 2010 | Autodesk AutoCAD 2006
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Vista pc will not print to ir3220 via PS driver
What version of Vista driver do you have? PS 4.64 is the latest that I can locate.
Aug 07, 2009 | Canon Office Equipment & Supplies
Can not print bold text.
Install newer drivers from brother.
Mar 04, 2018 | Office Equipment & Supplies
We have a workcentre M15i connected to a vista computer. We want to print from a xp computer to the workcentre. The xp only sees the workcentre if the vista computer is turned on. How do we get the xp...
We put a usb cable from the xp computer to the workcentre. We left the Vista computer connected to the workcentre via parallel cable. Not the solution we were hoping for but it does enable us to print from both computers
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
Bottom of page is cut off sometimes printing from vista computer
Are you useing vista print drivers for the vista computers or are they XP drivers?
Mar 06, 2009 | Digital Products Hewlett Packard OfficeJet...
HP laserjet 1320n keeps printing jetdirect configuration page
Are the proper drivers installed on each system?...Vista will not work properly on XP and vice versa. Make sure they are insttalled correctly
Mar 03, 2009 | HP LaserJet 1320 Printer
Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Jul 07, 2008 | Linksys Wireless-G WPS54G Print Server
HP DeskJet 890c InkJet Printer Logo
98 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
