Question about Jenn-Air JGR8850 Gas Kitchen Range
I have a Jenn Aire downdraft aluminum-foil exhaust duct system that's about 15 years old and it's dripping grease onto my basement ceiling. Can I replace the foil with a standard 6" aluminum pipe or will this become a fire safety issue?
    President:
  • 1,430 Answers
Go ahead no problem
Posted on Aug 05, 2010
Replacing fan switch jenn aire D156
I have a Radio Shack 3-in-one remote control 15-302 and I need codes for Dinex TV..it says it is 4 numbers
Jan 01, 2014 | Jenn-Air Cooktops
My Jenn air model JMC7010 turntable is not turning when in use. It turns very very slow if nothing on it, and It will make noise when put something on it. Can anyone help me to determine I can fix this...
Yor can Choose or Enter Your model number to make sure this fits.I looked for this for a very long time. I ordered several because it was so hard to find. I rated it a five because it fits prefect,
Amazon com NEW JENN AIR DOWNDRAFT ALUMINUM GREASE FILTER 71002111 FREE...
Feb 14, 2018 | Jenn-Air JMC7000 Microwave Oven
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
Can you cook hamburgers and pork chops on the griddle hot plate?..if so, should there be a drip pan beneath the holes in the griddle to catch the grease?
There should be a drip pan already but remove the griddle and line it with aluminum foil that way you can just roll up the foil and throw away and you don't have to clean the drip pan. If you cook pork you need to cover with a lid and you want to make sure you get the meat hot enough to be safe, get a thermometer from Wal Mart and it will have a probe and the temp the meat has to be in order to be safe. Chicken is 160 beef is 140 and I don't eat pork and don’t know the exact temp for it but the problem will have it on it. If this helped please rate me.
Aug 07, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn air downdraft
They should be pretty close to the same, if not, it would would very inexpensive and easy to modify or adapt the new one. Mostly the vent piping would have to be modified. Like I said though, you shouldnt have a problem at all.
Nov 16, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Replacement grease catcher
I am using a disposable foil loaf that I bent to fit in the drip space.
May 18, 2008 | George Foreman GGR50B Grill
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Melted Tin Foil in bottom of oven
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
Oct 23, 2007 | Kenmore 33169 Gas Single Oven
Jenn-Air JGR8850 Gas Kitchen Range Logo
234 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
