Question about Canon BJ 30 InkJet Printer
Canon F149200 - How do you replace ink cartridge?
SOURCE: ink cartridge problem
you may find that doing a clean and alignment assists with this problem.
Posted on Aug 20, 2008
  • 76 Answers
SOURCE: U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Posted on Oct 21, 2008
garydillon
  • 42 Answers
SOURCE: Need to replace ink cartridge
Go here: javascript:wssPopupWindow('http://gdlp01.c-wss.com/gds/0900002862/mp830_ug_us_v4.pdf',%20'mp830_ug_us_v4.pdf')
There are instructions with illustrations.
Posted on May 31, 2009
old marine
  • 2178 Answers
SOURCE: Ink Cartridge Replacement
With your hand beneath the control panel, lift straight up. The top half of the unit will open. If the power is ON, the cartridge unit will move from its parked area on the right side to the center, where you can see all the ink tanks. Tanks that are low or out of ink will be indicated by the light on the tank flashing. If the light is steady, the tank still has sufficient ink. Remove the tank by pushing the tab on the front of the tank and lifiting up.
Posted on Feb 10, 2010
nblady
  • 206 Answers
SOURCE: HOW DO I REPLACE MY INK CARTRIDGE IN MY CANON 2600 PRINTER?
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Good luck
Posted on Feb 15, 2010
Please help me to download the drivers of printer canon f149200
search the canon printers site
find driver down load for model f149200
check that the download is for your operating system (XP, WIN 7 WIN 10 etc) download and run
Apr 03, 2018 | Canon Office Equipment & Supplies
Canon IR5000 Error code E000014-0000, I replace already two times fixing motor but the same error code? Is this the only fixing problem? Can you help me?
Resolve Canon Printer error E05?
The Canon printer error E05 execute due to the compatibility issue related to ink cartridge installed in the printer. This Error E05 as studies by Canon Printer Support professionals also may execute if the Ink Cartridge is not accurately installed. Further the Ink Cartridge in Canon printers comes with a small opening via which it easily gets the capability to discharge the ink which needs to be utilized on a certain paper. It is needed, when the printer is not at all required for a considerable period of time, and the ink may get easily dried up by blocking the cartridge opening. The Canon printer error E05 is also known to be executed by the disarrangement issue of a cartridge in its holder, or even when the cartridge needs to be replaced. This is considered a common issue but yes, it can easily be resolved.
There are 3 methods to resolve Canon Printer error E05
Method 1: Resetting of the printer
    ·Turn on the Canon printer first
    ·Next, Canon Printer Technical Support technicians have suggested users to hold and then press the button for at-least 5 to 6 seconds to enable rebooting process of the printer
    ·It is now ready to be used by you.
    Method 2: This method deals with the reinstalling and clearing of the printer blockage
      ·Open the lid cover carefully from the rare top of the Canon printer.
      ·Next, ink cartridge installed in the printer will automatically be visible
      ·It is needed to press the two "click-locks" key which is located at the sides of the cartridge holder, and then you will see that the ink cartridge will pop-out to be taken off automatically.
      ·Now, Check the cartridge if it is having any sort of dust particles, or have dried ink in its opening that could be causing the blockage.
      ·Cleaning of the cartridges is required which is suggested to be done by tissue and then re-install the ink cartridge in its holder.
      ·If the error still occurs then, one needs to replace the ink cartridge immediately.
      Method 3: Replacing of the Ink Cartridge
        ·Buying an Ink cartridge of the Canon printer from a local electronics retailer is recommended in this method.
        ·Re-installation of the cartridge is necessary by following the Method1. Come and explore our Canon Printer Customer Support services now and get your issues related to Canon printer resolved. We are available for users all day long by promising them to deliver the utmost solution available with us according to latest market trends.for more Contact on Canon Printer Support Phone Number 1-800-213-8289 for Repair Canon Printer
Canon Printer Support Phone Number 1 8002138289 Tech Support
Mar 20, 2017 | Canon imageRUNNER 5000 Copier
Canon driver f149200 windows 7 suport
You can find canon f149200 driver here on this link
driverupdate us .Take a look and enjoy
Mar 14, 2012 | Canon Office Equipment & Supplies
The cartridge
Is this a Canon ink cartridge or a refilled ink cartridge or an after market type. If it is not a Canon ink cartridge then printer will reject the ink cartridge.
Dec 23, 2011 | Canon PIXMA Office Equipment & Supplies
New Canon ink tank not recognized.
Check that the cartridge chip is not soiled or damaged in any way... Give it a quick clean, check that there's no ink anywhere else on the cartridge as there are sensor points that an LED uses to check the cartridge ink levels too.
If none of that works, phone Canon and request a replacement as some cartridges are known to have faulty chips.
Jan 29, 2009 | Canon MX700 Office All-In-One InkJet...
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
Canon MP460 cartridge error
"Verify that you are using Canon(TM) cartridges. The technology has progressed to where they have modified the ink to be identified by their printers. You cannot currently use refill cartridge inks to refill Canon cartridges. If that is not your issue, then try removing and replacing the cartridge(s)and reset the ink level indicator.
Lets hope for the best!
Regards,
Eagle"
Honestly.. There is absolutely no way for Those Canon printers to "look inside" or "Detect" the formulation of ink inside the cartridge...
Canon CL-31, CL-41, CL-51, CL-52 Print cartridges have the highest electronic _Failure_ rate of anything other inkjet cartridge on the market. Canon is aware of this. Replacing the Cartridge is the only sure-fire way of fixing this.
*sometimes the printer will tell you its the color cartridge, when in fact its the black cartridge. its advised to replace them both during these error messages.. it'll save you a trip, and the customer service rep's head. haha"
Using an Aftermarket or "re-filled" canon original cartridge is a sustainable resource for anyone looking to re-use an end-user item, and save money in this "tied-selling" market.
I proved you wrong by replacing my inkjets with Oringinal Canon PG-40 black, and CL-41 color cartridge. I ran them until they were empty. Bypassed the Ink Metering System explained to me through the canon software provided during the printer installation, and continued to print with them until they were 110% bone dry empty, laying absolutely no ink on the page. this took approx. 3 hours from perfect start, to finish.
If "canon printers have progressed so much as to distinguish formulations of ink" then.. this canon sure was the PICK of the litter. it continued to print *** as the day it was purchased, while not laying a single droplet of ink on the page.
get a life. stop dissing the aftermarket with your un-supported facts!
reguards,
inkjetech_007
Oct 10, 2007 | Office Equipment & Supplies
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon BJ 30 InkJet Printer Logo
969 people viewed this question
old marine
old marine
