Question about Dometic Rooftop RV Air Conditioner
Water coming from ceiling about 3 foot from unit
  • 36 Answers
Does the unit work other, than the leaking?If it does you need to install a square seal between the ac unit and the roof.You can either buy the seal from Ebay or I would recomend an Rv Repair place.(They Might even be able to install it where the Rv Sits)
Posted on Aug 05, 2010
For a moveving i need 2048 sqr foot wht would that be in cbi foot
Square foot is a measure of area, cubic foot is a measure of volume. There is no direct conversion between them.
For example, if you have 2048 square feet with a one foot ceiling, you would have 2048 cubic feet. If the ceiling was raised to ten feet, you would have 20480 cubic feet.
Nov 17, 2016 | Cars & Trucks
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
What is 9600 cubic ft converted to square ft?
Cubic foot is a unit of volume. Square foot is a unit of area. There is no direct conversion between them.
A 9600 cubic foot room with a ten-foot high ceiling is 960 square feet. If the roof is eight feet high, the area is 1200 square feet. If the roof is 12 feet high, the area is 800 square feet.
Jul 02, 2014 | Office Equipment & Supplies
Need for a home dehumidifier for a 120 square meters space
normall you will need one pint of water for each 1,000 cubic feed of space in your . . example. 2,000 square foot with 8 foot ceiling would contain some 16,000 cubic feet. = 16 pint per day capcity to dehumidify the area.
God bless you
Oct 29, 2013 | DeLonghi DH100P Dehumidifier
I have a Hampton Bay, Glendale 52 inch ceiling fan/light. I've installed ceiling fans in the past and am used to having 4 wires coming out of the unit - black, blue, white and green. There are black,...
green on the fan is for grounding the device, some have only a braided bare cooper line. grounding is a safety essential and all modern UL tested electrical devices will have some means of grounding to the homes grounding circuit (the bare copper line). check the installation instructions for the proper grounding method. Then you might consider having a qualified electrician install your fans.
Jun 11, 2011 | Heating & Cooling
Repar water pump on 1996 35hp johnson
VERY EASY REPLACEMENT
REMOVE PHILIPS HEAD SCREWS THAT HOLDS THE PLASTIC WATER STRAINERS ON THE FOOTOF THE MOTOR,
NEXT LOOSEN THE HEX FITTINGS 7/16 OR 1/2 WRENCH SIZE THAT WERE COVERED BY THE STRAINERS
NEXT REMOVE THE 2 STAINLESS STEEL BOLTS THAT ATTACH THE FOOT TO THE LOWER UNIT.. BOLTS COME OUT FROM THE BOTTOM,, NEXT LOOSEN THE NUT ON THE FRONT OF THE FOOT FACING THE TRANSOM LEAVE A FEW THREADS TO HOLD THE FOOT SO IT DOSEN'T FALL. NEXT WIGGLE AND SHAKE THE FOOT
TO LOOSEN IT FROM THE LOWER UNIT . NEXT STEP REMOVE THE NUT WHILE HOLDING UP ON THE FOOT THEN SLOWLY REMOVE FOOT ASSEMBLY WITH DRIVE SHAFT.
NEXT REMOVE THE O RING FROM THE FITTING THEN REMOVE THE FITTING FROM THE SHIFT ROD THERE SHOULD BE A BIGGER O'RING ON THE SHIFT ROD NEXT TO THE WATER PUMP HOUSING . REMOVE BOLTS HOLDING WATER PUMP HOUSING ON THE FOOT ASSEMBLY LIFT OFF HOUSING LOOK FOR IMPELLER KEY TO FALL OUT . I RECOMMEND REPLACING IMPELLER AND HOUSING AS A KIT . INSTALL IN REVERSE ORDER .
IT'S A PIECE OF CAKE ...
Aug 06, 2010 | Boating
Distance between blades and ceiling?
I'd be more concerned on how much clearance you have between the blades and the floor since you mention a "low" ceiling. The efficiency drops
rapidly as you get too close to the ceiling. You also have to worry about the wobbling of the unit. I wouldn't go less that 8"
May 15, 2010 | Aloha Housewares (93645) Ceiling Fan
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
On my 28 foot Itasca motorhome the air conditioner is leaking water through the gasket on the roof. I pulled the inside cover off and took out the four big boltd holding the roof top section, but I can't...
You need to find where the drain is. The water should flow to a drain and not into the unit. Once you get the condensation draining properly you can use a good quality silicone to seat around the unit. You might check at a RV parts place and find a product they recommend for RV roofs. Hope this helps.
Nov 19, 2009 | Dometic Rooftop RV Air Conditioner
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
Dometic Rooftop RV Air Conditioner Logo
193 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
