I have a Technics system, the Cd player SL-PJ38A has stopped producing any sound but is reading and playing the CD. I have the possibility of buying a SL-PJ26A to replace it with at £8, assume that will work as a direct replacement but struggling to locate and tech spec on this one.
3 Suggested Answers
  • 4234 Answers
SOURCE: The cd player now wont read the Cd, the tracks
The clicking is the lens attempting to focus on the CD. Try cleaning the lens using a cotton swab and alcohol. If that fails to resolve the problem, the optics will need to be replaced.
Dan
Posted on Jul 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: My Technics SL-PJ26A seems to
Try this
http://www.repairfaq.org/sam/cdfaq.htm
Posted on Feb 03, 2011
CD player will not play, how do i repair?
I suspect on something that old, the motor that spins the CD is worn out. Place 1 CD in position and make note of the exact position of the words on the CD, let the player go through all 5 positions and see if the CD is still in the exact position that it was when you started. If this is the problem there's usually no easy way to fix it.
There is also the possibility that the read head is no longer moving in and out smoothly, you'll have to take the unit apart and re-grease the slides with light lithium grease.
The read head being dirty or too dusty is another possibility, but even less likely. When you get it apart, clean the read head with a cotton swab and rubbing alcohol, anything harsher might damage the components.
Oct 03, 2016 | Technics Audio Players & Recorders
Technics sl mc410
The Optical Pickup(laser) has worn out. When you place a disc in the drawer, it has to load and read the TOC(table of contacts) if if can't read that, it assumes there is no CD in the drawer and stops or ejects.
Aug 28, 2014 | Technics Audio Players & Recorders
I have a Technics CD changer SL-PD867 it will not play re writable disc's all other disc ok
You should realize that this player is about 20 years old.
It was not designed to read CD-R or CD-RW media.
The signal from these media types is different from audio CDs you buy.
May 11, 2014 | Technics SL-DZ1200 CD Player
Reads all the cd but only plays the single cd everytime
This sound like a mode setting problem. Can you manually select another of the discs and it plays?
Dec 10, 2012 | Technics SL-MC7 110-Disc CD Changer
I burned a CD on my PC to keep in my car and it plays OK in the car and on my PC, but does not play on my Technics SL-PD687 5 disc cd player. It's recorded in *.cda format and it's on a CD-RW. Any...
The problem with old CD Players are that they sometimes are a little fidgety when it comes to reading CDRs.
You could try burning a new CD on the lowest possible setting, say 2x or 4x.
Also try changing the CDR brand as some cheap CDRs are prone to not reading in old CD Drives.
Try using a regular CD-R (CD recordable - record only once) instead of a CD-RW (CD rewritable - rewrite multiple times). CD-RW use a different "ink" to write the data to the disc and can be re-recorded/erased a couple of times before it loses its ability to write effectively to it.
Mar 05, 2011 | Technics SL-PD687 5-Disc CD Changer
I buy a used technics sl-pg480a cd player and after i inserted a cd, there is "no disc" on display...i try with different cd's (mp3, avi,...) and it's always the same...i have opened a box and...
If it doesn't turn the disc it can't read the data and 'know' from that there is a compatible disc inserted.
You may have gotten hosed by the seller. Until you get it to play with a commercial music CD I wouldn't try anything non-standard or home-grown. It doesn't play anything but CD-A music so MP3 and AVI discs would not be recognized anyway.
Before you dive in and possibly wreck it, read this...
The manual:
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PG480A
Feb 20, 2011 | Technics SL-PG480A CD Player
Does the Technics SL-MC6 play home made CD's? CD-R? CD-RW?
i've not come across a technics cd player yet that doesn't play cd-rs but they definatly don't play cd-rws.
Aug 02, 2009 | Technics SL-MC6 CD Player
My Technics SL-DZ1200 will not play certain MP3 tracks. It will play some, but on others the message "track error" appears. these same disks will play just fine on the other cd player machines I have...
I believe it can only read certain bitrates. I noticed that if I run the track error files through audacity and re-save as an mp3 with 192 kbps encoding it plays fine. Give it a try - re-encoding.
Jun 08, 2009 | Technics SL-DZ1200 CD Player
Technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Oct 07, 2008 | Technics SL-PG480A CD Player
264 people viewed this question
 Grubhead
Grubhead
