Question about Xerox Office Equipment & Supplies
I cannot fax to certain phone numbers. It comes back failed.
  • 137 Answers
You are being blocked by the phone company for some reason. Check with them. Its not the fax.
Posted on Aug 14, 2010
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
When incoming fax is coming, mfax machine answers but then says fax not detected on screen. I have tried manually receiving the fax as well and this does not work either.
This can be caused by the incoming call not actually being a fax machine at the other end... like someone has dialled the wrong number.
If you are really certain that the incoming call is actually a fax, then check that you have the phone line plugged into the correct socket on the back of the device.
Dec 03, 2009 | HP Office Equipment & Supplies
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Can't send a fax.
You need to have a phone line not just internet connection to send a fax. Unless you have an account with a fax to email company. So you need to hook your fax machine up to your already exsisting phone line, get a seperate phone number for fax purposes or serch the internet for a fax via email company.
Jan 14, 2009 | Lexmark P4350 All-In-One InkJet Printer
Unable to fax to a certain number
She may have a digital phone line, such as DSL...Vonage...etc.
Sep 11, 2008 | Brother IntelliFax-2820 Laser Fax
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
When faxing, what is Error 387? Can fax other places, why not this place?
Specifically, error code 387 on that machine is : Try to send the fax at a different time when telephone line conditions have improved. There is nothing wrong with your machine that I can tell from your description. It sounds like it is trying to handshake, fax term for connect, but does not complete. I had the same thing happen to me yesterday with some very important papers. I even called the person at the other end and they said they had been receiving faxes ok. Took me 4 tries but finally went through. It's just the phone lines. Keep trying. It can take several tries. If this helped please rate a big 4 fix ya. If you can't get through no matter how many times you try just post a comment and I'll be happy to come back and help you out.
Mar 25, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Send and receive fax
Faxes cannot be received but they can be sent Review the information below to determine why faxes are not being received.
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections
  4. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine.
Faxes cannot be sent but can be received Follow the steps below to correct the problem.
  1. Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
  2. If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
  3. If you are trying to fax from the computer with a model that supports PC faxing and the fax does not try to dial when you send a fax job, test the communications to the all-in-one by clicking Status in the Director, or by trying to print to the all-in-one.
    • If this is reported as disconnected or printing fails, verify that the communications cable from the computer to the all-in-one is connected correctly and restart the computer.
    • If communications still cannot be established, troubleshoot the communications
  4. Faxes fail intermittently or with only one fax number
    • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
    • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
    • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
    • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
    • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
    • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Nov 24, 2007 | HP C7200-69016 Network Adapter
Receiving a fax
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
475 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
