Question about Honda Pressure Washer PSI 3000
Husky ran great for couple of hours. Now no pressure at all. Water comes thru for suds, but no near enough. Engine runs fine but will not build pressure. Checked for trash blockage-all clear. Thanks, Ed Kent---kented1@bellsouth.net
  • 5,603 Answers
Same old problem... water admitance valve sticking.
Remove the valve spool and clean the bore with crocus cloth on a dowel rod.
Replace O rings and lube lightly with plumber's grease. Reassemble... good as new!
The valve senses pressure and blocks further input water. It sticks in the high pressure position blocking water flow.
Posted on Aug 05, 2010
  • anitalynnsto May 18, 2011
    Where is the o ring and valve spool on the husky 1800 electric pressure washer?
Why does it build pressure, but when I squeeze the trigger the engine stays at idle?
POSSIBLE this look picture hose coupling with water stop put on the tap side or lime in valves after long time or a nozzle with dirt close beaten
clogged nozzle on the lance
Bypass not working (lyme)
if you disconnect the lance and the handle grip is giving enough water and water comes out then the nozzle clean it with a little paperclip.25944841-me02dbjx1ofpduv3i0g3gg4u-5-0.jpg
Nov 06, 2015 | Garden
Keurig b70 platinum motor runs but no water comes out
I have had the same issue with mine. If you fill it up with water and press brew. It only spits out a little to no water but you can hear it running. I found out later on that there was calcium build up on the heating element and through out the lines. I just ran straight vinegar through the machine a couple of times and then let it sit for a couple of hours with it still on. Even thought it is not coming out its still in the lines and it seemed to **** it up. After a while it seemed to be fine and work fine as well. Just have to rinse it out a couple of times with water to get the vinegar from making your coffee taste terrible.
Mar 18, 2013 | Keurig B60 Coffee Maker
Husky pressure washer 80432. 1 year old. worked before the winter. no pressure this summer. honda engine runs fine. replaced the pump from the bottom of the engine down... still doesn't pressurize. ...
Check the inlet strainer where the water supply hose is attached,this is located just inside the coupling where you hook up the water hose.
Jul 30, 2010 | Garden
My 1 year old gas powered Husky model HU80432 starts and runs fine but gets no pressure from the wand. Water is running freely through all connections and hoses so there are no obstructions, just no...
Lime/calcium build up in the pump.
Pour a large amount of liquid TSP into the fresh water inlet and let it sit for two or three days, the longer the better.
This is how I fixed my no pressure problem.
Works great now
Jul 28, 2010 | Garden
Husky 202900 when i turn it on motor runs but it but will not bui
when i turn it on motor runs but it will not build up air pressure
Apr 13, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky 2400 psi honda engine ran fine all day
It sounds like the bypass valve is stuck. Do you have a parts diagram?
Jun 27, 2009 | Honda Garden
Honda Pressure Washer PSI 3000 Logo
571 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
